Filebeat pods are restarting with "panic: interface conversion: interface {} is cache.DeletedFinalStateUnknown, not *v1.Pod" error
I have deployed Filebeat -> Logstash -> elasticseach -> kibana in OKD-3.11 platform running on Openstack Centos-7.6 VMs. Using v7.10.2 oss docker images for the deployment.
There are 3 filebeat pods running one on each worker node, 1 logstash pod, 1 elasticsearch pod and a kibana pod running on the cluster.
filebeat.yml
  filebeat.autodiscover:
    providers:
      - type: kubernetes
        node: ${NODE_NAME}
        tags:
          - "kube-logs"
        templates:
          - condition:
              or:
                - contains:
                    kubernetes.pod.name: "ne-mgmt"
                - contains:
                    kubernetes.pod.name: "list-manager"
                - contains:
                    kubernetes.pod.name: "scheduler-mgmt"
                - contains:
                    kubernetes.pod.name: "sync-ne"
                - contains:
                    kubernetes.pod.name: "file-manager"
                - contains:
                    kubernetes.pod.name: "dash-board"
                - contains:
                    kubernetes.pod.name: "ne-db-manager"
                - contains:
                    kubernetes.pod.name: "config-manager"
                - contains:
                    kubernetes.pod.name: "report-manager"
                - contains:
                    kubernetes.pod.name: "clean-backup"
                - contains:
                    kubernetes.pod.name: "warrior"
                - contains:
                    kubernetes.pod.name: "ne-backup"
                - contains:
                    kubernetes.pod.name: "ne-restore"
            config:
              - type: container
                paths:
                  - "/var/log/containers/*-${data.kubernetes.container.id}.log"
  logging.level: debug
  processors:
    - drop_event:
        when.or:
           - equals:
               kubernetes.namespace: "kube-system"
           - equals:
               kubernetes.namespace: "default"
           - equals:
               kubernetes.namespace: "logging"
  output.logstash:
    hosts: ["logstash-service.logging:5044"]
    index: filebeat
    pretty: true
  setup.template.name: "filebeat"
  setup.template.pattern: "filebeat-*"
The Filebeat pods are restarting with "cache.DeletedFinalStateUnknown" as mentioned below,
2021-03-06T11:46:39.829Z        DEBUG   [input] input/input.go:139      Run input
2021-03-06T11:46:39.829Z        DEBUG   [input] log/input.go:205        Start next scan
2021-03-06T11:46:39.830Z        DEBUG   [input] log/input.go:439        Check file for harvesting: /var/log/containers/1615031071454-ne-backup-1615031071454-dz52x_task-execution_tes-job-ctr-ffaaen22-1615031073017-572e5c521cc95667c7a75a5903e13b12f5c8c6cdbe18e42005602986eaee8c07.log
2021-03-06T11:46:39.830Z        DEBUG   [input] log/input.go:530        Update existing file for harvesting: /var/log/containers/1615031071454-ne-backup-1615031071454-dz52x_task-execution_tes-job-ctr-ffaaen22-1615031073017-572e5c521cc95667c7a75a5903e13b12f5c8c6cdbe18e42005602986eaee8c07.log, offset: 1115
2021-03-06T11:46:39.830Z        DEBUG   [input] log/input.go:582        Harvester for file is still running: /var/log/containers/1615031071454-ne-backup-1615031071454-dz52x_task-execution_tes-job-ctr-ffaaen22-1615031073017-572e5c521cc95667c7a75a5903e13b12f5c8c6cdbe18e42005602986eaee8c07.log
2021-03-06T11:46:39.830Z        DEBUG   [input] log/input.go:226        input states cleaned up. Before: 1, After: 1, Pending: 0
goroutine 71680 [running]:
github.com/elastic/beats/v7/libbeat/autodiscover/providers/kubernetes.(*pod).OnDelete.func1()
        /go/src/github.com/elastic/beats/libbeat/autodiscover/providers/kubernetes/pod.go:174 +0x7c
created by time.goFunc
        /usr/local/go/src/time/sleep.go:168 +0x44
The filebeat pod logs are extending for more than 1 lakh lines so added only a portion of the log here - filebeat_DeletedFinalStateUnknown - 2e44ff3d
Observations -
Filebeat pods are restarting every time after the "etcd_master" & "api_master" docker containers are exiting.
Platform Details -
Master node - 1
Worker Nodes - 3
Platform - OKD-3.11
OS - Centos-7.6
Kubernetes - 1.11
Resources Allocated to Filebeat -
RAM - 2 to 4 Gb
CPU - 2 to 4 cores
Resources allocated to Logstash -
RAM - 2 to 4 Gb
CPU - 2 to 4 cores
Please let me know if you need any more details and suggest me the steps to resolve this.
