Hi, there's no such logstash.conf included on binary files. You need to create it.
#Input here
#Output here
#Input here
#Output here
Go to /usr/share/logstash/bin
from there, you can execute your command
./logstash -f /path/to/your/config/file/YourConfigFileName.conf --path.settings /path/to/your/logstash-yml --config.reload.automatic
Thanks got problem solved...
But again I am getting the below error. I am trying to avoid the '\n\t' which I see inside the stacktrace and messages of the JSON output. I configured with the below configuration, but it throws below error
stdin {
mutate {
strip => "message"
output
stdout {
I get the below error message
sawyer@ford11:/usr/share/logstash/bin$ ./logstash -f /etc/logstash/conf.d/logstash.conf
WARNING: Could not find logstash.yml which is typically located in $LS_HOME/config or
/etc/logstash. You can specify the path using --path.settings. Continuing using the defaults
Could not find log4j2 configuration at path /usr/share/logstash/config/log4j2.properties. Using
default config which logs errors to the console[ERROR] 2018-01-29 15:48:08.734 [Ruby-0-Thread-
1: /usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/stud-0.0.23/lib/stud/task.rb:22] agent -
Failed to execute action {:action=>LogStash::PipelineAction::Create/pipeline_id:main,
:exception=>"LogStash::ConfigurationError", :message=>"Expected one of #, input, filter, output
at line 1, column 1 (byte 1) after ", :backtrace=>["/usr/share/logstash/logstash-
core/lib/logstash/compiler.rb:42:in `compile_imperative'", "/usr/share/logstash/logstash-
core/lib/logstash/compiler.rb:50:in `compile_graph'", "/usr/share/logstash/logstash-
core/lib/logstash/compiler.rb:12:in `block in compile_sources'", "org/jruby/RubyArray.java:2486:in
`map'", "/usr/share/logstash/logstash-core/lib/logstash/compiler.rb:11:in `compile_sources'",
"/usr/share/logstash/logstash-core/lib/logstash/pipeline.rb:51:in `initialize'",
"/usr/share/logstash/logstash-core/lib/logstash/pipeline.rb:171:in `initialize'",
"/usr/share/logstash/logstash-core/lib/logstash/pipeline_action/create.rb:40:in `execute'",
"/usr/share/logstash/logstash-core/lib/logstash/agent.rb:335:in `block in converge_state'",
"/usr/share/logstash/logstash-core/lib/logstash/agent.rb:141:in `with_pipelines'",
"/usr/share/logstash/logstash-core/lib/logstash/agent.rb:332:in `block in converge_state'",
"org/jruby/RubyArray.java:1734:in `each'", "/usr/share/logstash/logstash-
core/lib/logstash/agent.rb:319:in `converge_state'", "/usr/share/logstash/logstash-
core/lib/logstash/agent.rb:166:in `block in converge_state_and_update'",
"/usr/share/logstash/logstash-core/lib/logstash/agent.rb:164:in `converge_state_and_update'",
"/usr/share/logstash/logstash-core/lib/logstash/agent.rb:90:in `execute'",
"/usr/share/logstash/logstash-core/lib/logstash/runner.rb:343:in `block in execute'",
"/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/stud-0.0.23/lib/stud/task.rb:24:in `block in
initialize'"]}
Please change your config output to
stdout { codec => rubydebug }
Again when I apply \n\t to the input as below I see Hi '\n\t inside the message. How do I get output without \n\t
The stdin plugin is now waiting for input: Hi\n\t
"@timestamp" => 2018-01-29T20:45:02.759Z,
"@version" => "1",
"message" => "Hi\\n\\t",
"host" => "algo-11"
I have used the below config provided at the link
https://www.elastic.co/guide/en/logstash/current/multiline.html
stdin {
codec => multiline {
pattern => "^\s"
what => "previous"
