Metricset 'postgresql/bgwriter' is not registered, module not found
What command are you using to start Metricbeat?
/etc/init.d/metricbeat start
but to avoid the error i had to edit that file and add at the top:
### END INIT INFO
unset -v PGSERVICEFILE
unset -v PGSYSCONFDIR
unset -v PGSSLMODE
If metricbeat is incompatible with those vars i think the start script should unset them by default to avoid this error to users using it.
That job is generally left to service on SysV. From man service:
service runs a System V init script in as predictable environment as possible, removing most environment variables and with current working directory set to /.
So try running sudo service metricbeat start. That should execute the service from a clean environment.
