Index level settings are wiped-out from v5.2.2
Hello techies
we are using elasticsearch 2.1.0(centos7) servers on production.
we want to upgrade to v5.2.2 very soon.
Following parameters are using while creating new indexes.
index.translog.flush_threshold_ops: 100000
index.number_of_shards: 5
index.number_of_replicas: 1
index.refresh_interval: 60s
Q: index.translog.flush_threshold_ops option is deprecated from v5.0.0
can you please suggest alternative for above?
You can update those settings as below:
PUT /twitter/_settings
    "index" : {
        "translog.flush_threshold_ops" : 100000
More over you can refer the docs here.
https://www.elastic.co/guide/en/elasticsearch/reference/current/indices-update-settings.html
Following error observed while applying threshold settings.
"error": {
"root_cause": [
"reason": "unknown setting [index.translog.flush_threshold_ops] did you mean [index.translog.flush_threshold_size]?"
"status": 400
i want to use index level setting using JAVA API
`The index.translog.[quote="kishore419, post:3, topic:81975"]
See here : https://www.elastic.co/guide/en/elasticsearch/reference/current/breaking_50_settings_changes.html#_translog_settings
The index.translog.flush_threshold_ops setting is not supported anymore. In order to control flushes based on the transaction log growth use index.translog.flush_threshold_size instead.
it works for me
thanks prashant.
