I want to send Auditbeat and filebeats logs in same index over Logstash. Filebeat is already successfully sending the data. But i dont know how i get Auditbeat logs in the same index because there is no output_type tag. I need the output_type for Logstash.
@Samau4ka I would not recommend having a different index per server, depending on the number of servers and the naming you are using it could generate a lot of shards on Elasticsearch.
If I were you I would keep a time-based index per beats and you can achieve the same thing by filtering on the beat.host or 'beat.hostname' field in kibana to get the information for a specific host. You can also add custom fields if you want more granularity. You can check our doc to see the default fields.
logo are trademarks of the
Apache Software Foundation
