Beginner Questions - Interaction Filebeat and Modules and General Q
Hey,
im new to ELK Stack and installed a Linux Server with Filebeat, Logstash, Elastic and Kibana.
I want to get the syslog and netflow Streams from Palo Alto FW / Cisco 2900 Series / WLAN and some more other Syslog Devices.
My Problem is to understand the interaction between filebeat and the modules.
The Setup is syslog/netflow -> filebeat -> logstash -> elastic -> kibana.
I have multiple Syslog-Sources. Syslog itself is RFC-5424 Standard, so it should be safe, that the Datas from all Systems are correct.
My (perhaps stupid) Questions are:
  • Which System/Config is responsible to split the Streams for Kibana (Source-Network A = Pattern A, Source-Network B = Pattern B) ?
  • I dont get any Syslog into Kibana, tcpdump reports this Datas (Port 514). How do you debug the individual Instances ? Or simple a wrong Config ?
  • in Filebeat i have filebeat.inputs and filebeat.config.modules. Do i need the type netflow or syslog under the filebeat.inputs when ive been enabled the modules ? thought no, the netflow streams seems good.
  • why do i have to setup in filebeat.yml the Section with Kibana, in my world i give the netflow/syslogs to logstash directly ?
Thanks for help.
Configs:
filebeat.yml
# ============================== Filebeat inputs ===============================
filebeat.inputs:
- type: log
  enabled: false
  paths:
    - /var/log/*.log
- type: filestream
  enabled: false
  paths:
    - /var/log/*.log
#- type: netflow
#  max_message_size: 10KiB
#  host: "0.0.0.0:2055"
#  protocols: [ v5, v9, ipfix ]
#  expiration_timeout: 30m
#  queue_size: 8192
#  custom_definitions:
#  - path/to/fields.yml
#  detect_sequence_reset: true
# ============================== Filebeat modules ==============================
filebeat.config.modules:
  enabled: true
  reload.enabled: false
# ======================= Elasticsearch template setting =======================
#setup.template.settings:
#  index.number_of_shards: 1
# ================================== General ===================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name: Filebeat-local
# The tags of the shipper are included in their own field with each
# transaction published.
# Optional fields that you can specify to add additional information to the
# output.
#fields:
#  env: staging
# ================================= Dashboards =================================
# These settings control loading the sample dashboards to the Kibana index. Loading
# the dashboards is disabled by default and can be enabled either by setting the
# options here or by using the `setup` command.
#setup.dashboards.enabled: false
# The URL from where to download the dashboards archive. By default this URL
# has a value which is computed based on the Beat name and version. For released
# versions, this URL points to the dashboard archive on the artifacts.elastic.co
# website.
#setup.dashboards.url:
# =================================== Kibana ===================================
setup.kibana:
  # Kibana Host
  # Scheme and port can be left out and will be set to the default (http and 5601)
  # In case you specify and additional path, the scheme is required: http://localhost:5601/path
  # IPv6 addresses should always be defined as: https://[2001:db8::1]:5601
  host: "localhost:5601"
  # Kibana Space ID
  # ID of the Kibana Space into which the dashboards should be loaded. By default,
  # the Default Space will be used.
  #space.id:
# ================================== Outputs ===================================
# ---------------------------- Elasticsearch Output ----------------------------
#output.elasticsearch:
#  hosts: ["localhost:9200"]
# ------------------------------ Logstash Output -------------------------------
output.logstash:
  # The Logstash hosts
  hosts: ["localhost:5044"]
  # Set gzip compression level.
  #compression_level: 3
  # Optional SSL. By default is off.
  # Client Certificate Key
# ================================= Processors =================================
processors:
  - add_host_metadata: ~
  - add_cloud_metadata: ~
#processors:
#  - add_host_metadata:
#      when.not.contains.tags: forwarded
#  - add_cloud_metadata: ~
#  - add_docker_metadata: ~
#  - add_kubernetes_metadata: ~
# ================================== Logging ===================================
# Sets log level. The default log level is info.
# Available log levels are: error, warning, info, debug
logging.level: info
# At debug level, you can selectively enable logging only for some components.
# To enable all selectors use ["*"]. Examples of other selectors are "beat",
# "publisher", "service".
#logging.selectors: ["*"]
netflow.yml
# Module: netflow
# Docs: https://www.elastic.co/guide/en/beats/filebeat/7.11/filebeat-module-netflow.html
- module: netflow
  log:
    enabled: true
    var:
      netflow_host: 0.0.0.0
      netflow_port: 2055
      # internal_networks specifies which networks are considered internal or private
      # you can specify either a CIDR block or any of the special named ranges listed
      # at: https://www.elastic.co/guide/en/beats/filebeat/current/defining-processors.html#condition-network
      internal_networks:
        - private
system.yml
# Module: system
# Docs: https://www.elastic.co/guide/en/beats/filebeat/7.11/filebeat-module-system.html
- module: system
  # Syslog
  syslog:
    enabled: true
    # Set custom paths for the log files. If left empty,
    # Filebeat will choose the paths depending on your OS.
    #var.paths:
  # Authorization logs
  auth:
    enabled: true
    #var.paths:
logstash.yml
# Settings file in YAML
# Settings can be specified either in hierarchical form, e.g.:
#   pipeline:
#     batch:
#       size: 125
#       delay: 5
# Or as flat keys:
#   pipeline.batch.size: 125
#   pipeline.batch.delay: 5
# ------------  Node identity ------------
# Use a descriptive name for the node:
# node.name: test
# If omitted the node name will default to the machine's host name
# ------------ Data path ------------------
# Which directory should be used by logstash and its plugins
# for any persistent needs. Defaults to LOGSTASH_HOME/data
path.data: /var/lib/logstash
# ------------ Pipeline Settings --------------
# The ID of the pipeline.
# pipeline.id: main
# Set the number of workers that will, in parallel, execute the filters+outputs
# stage of the pipeline.
# This defaults to the number of the host's CPU cores.
pipeline.workers: 6
# How many events to retrieve from inputs before sending to filters+workers
# How long to wait in milliseconds while polling for the next event
# before dispatching an undersized batch to filters+outputs
pipeline.batch.delay: 50
# Force Logstash to exit during shutdown even if there are still inflight
# events in memory. By default, logstash will refuse to quit until all
# received events have been pushed to the outputs.
# WARNING: enabling this can lead to data loss during shutdown
# pipeline.unsafe_shutdown: false
# Set the pipeline event ordering. Options are "auto" (the default), "true" or "false".
# "auto" will  automatically enable ordering if the 'pipeline.workers' setting
# is also set to '1'.
# "true" will enforce ordering on the pipeline and prevent logstash from starting
# if there are multiple workers.
# "false" will disable any extra processing necessary for preserving ordering.
pipeline.ordered: auto
# ------------ Pipeline Configuration Settings --------------
# Where to fetch the pipeline configuration for the main pipeline
# path.config:
# Pipeline configuration string for the main pipeline
# config.string:
# At startup, test if the configuration is valid and exit (dry run)
# config.test_and_exit: false
# Periodically check if the configuration has changed and reload the pipeline
# This can also be triggered manually through the SIGHUP signal
# config.reload.automatic: false
# How often to check if the pipeline configuration has changed (in seconds)
# Note that the unit value (s) is required. Values without a qualifier (e.g. 60)
# are treated as nanoseconds.
# Setting the interval this way is not recommended and might change in later versions.
# config.reload.interval: 3s
# Show fully compiled configuration as debug log message
# NOTE: --log.level must be 'debug'
# config.debug: false
# When enabled, process escaped characters such as \n and \" in strings in the
# pipeline configuration files.
# config.support_escapes: false
# ------------ Module Settings ---------------
# Define modules here.  Modules definitions must be defined as an array.
# The simple way to see this is to prepend each `name` with a `-`, and keep
# all associated variables under the `name` they are associated with, and
# above the next, like this:
# modules:
#   - name: MODULE_NAME
#     var.PLUGINTYPE1.PLUGINNAME1.KEY1: VALUE
#     var.PLUGINTYPE1.PLUGINNAME1.KEY2: VALUE
#     var.PLUGINTYPE2.PLUGINNAME1.KEY1: VALUE
#     var.PLUGINTYPE3.PLUGINNAME3.KEY1: VALUE
# Module variable names must be in the format of
# var.PLUGIN_TYPE.PLUGIN_NAME.KEY
# modules:
# ------------ Queuing Settings --------------
# Internal queuing model, "memory" for legacy in-memory based queuing and
# "persisted" for disk-based acked queueing. Defaults is memory
queue.type: memory
# If using queue.type: persisted, the directory path where the data files will be stored.
# Default is path.data/queue
# path.queue:
# If using queue.type: persisted, the page data files size. The queue data consists of
# append-only data files separated into pages. Default is 64mb
# queue.page_capacity: 64mb
# If using queue.type: persisted, the maximum number of unread events in the queue.
# Default is 0 (unlimited)
# queue.max_events: 0
# If using queue.type: persisted, the total capacity of the queue in number of bytes.
# If you would like more unacked events to be buffered in Logstash, you can increase the
# capacity using this setting. Please make sure your disk drive has capacity greater than
# the size specified here. If both max_bytes and max_events are specified, Logstash will pick
# whichever criteria is reached first
# Default is 1024mb or 1gb
# queue.max_bytes: 1024mb
# If using queue.type: persisted, the maximum number of acked events before forcing a checkpoint
# Default is 1024, 0 for unlimited
# queue.checkpoint.acks: 1024
# If using queue.type: persisted, the maximum number of written events before forcing a checkpoint
# queue.checkpoint.writes: 1024
# If using queue.type: persisted, the interval in milliseconds when a checkpoint is forced on the head page
# Default is 1000, 0 for no periodic checkpoint.
# queue.checkpoint.interval: 1000
# ------------ Debugging Settings --------------
# Options for log.level:
#   * fatal
#   * error
#   * warn
#   * info (default)
#   * debug
#   * trace
# log.level: info
path.logs: /var/log/logstash
# ------------ Other Settings --------------
# Where to find custom plugins
# path.plugins: []
# Flag to output log lines of each pipeline in its separate log file. Each log filename contains the pipeline.name
# Default is false
# pipeline.separate_logs: false
