The docker container shuts down when the test exits. Any suggestions on how? The REST client works. Just not the transport client...
Add a breakpoint in your tests or a sleep that takes enough time for you to run docker ps and logs.
Oh yeah
[2018-06-14T12:06:39,807][INFO ][o.e.n.Node ] [] initializing ...
[2018-06-14T12:06:39,902][INFO ][o.e.e.NodeEnvironment ] [zXCixBy] using [1] data paths, mounts [[/ (overlay)]], net usable_space [57.8gb], net total_space [62.7gb], types [overlay]
[2018-06-14T12:06:39,903][INFO ][o.e.e.NodeEnvironment ] [zXCixBy] heap size [1007.3mb], compressed ordinary object pointers [true]
[2018-06-14T12:06:39,905][INFO ][o.e.n.Node ] node name [zXCixBy] derived from node ID [zXCixByNTHSbNB09Bx5L-A]; set [node.name] to override
[2018-06-14T12:06:39,905][INFO ][o.e.n.Node ] version[6.2.4], pid[1], build[ccec39f/2018-04-12T20:37:28.497551Z], OS[Linux/4.9.87-linuxkit-aufs/amd64], JVM[Oracle Corporation/OpenJDK 64-Bit Server VM/1.8.0_161/25.161-b14]
[2018-06-14T12:06:39,905][INFO ][o.e.n.Node ] JVM arguments [-Xms1g, -Xmx1g, -XX:+UseConcMarkSweepGC, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Djava.io.tmpdir=/tmp/elasticsearch.x74V4bHC, -XX:+HeapDumpOnOutOfMemoryError, -XX:+PrintGCDetails, -XX:+PrintGCDateStamps, -XX:+PrintTenuringDistribution, -XX:+PrintGCApplicationStoppedTime, -Xloggc:logs/gc.log, -XX:+UseGCLogFileRotation, -XX:NumberOfGCLogFiles=32, -XX:GCLogFileSize=64m, -Des.cgroups.hierarchy.override=/, -Des.path.home=/usr/share/elasticsearch, -Des.path.conf=/usr/share/elasticsearch/config]
[2018-06-14T12:06:43,490][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [aggs-matrix-stats]
[2018-06-14T12:06:43,490][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [analysis-common]
[2018-06-14T12:06:43,490][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [ingest-common]
[2018-06-14T12:06:43,491][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [lang-expression]
[2018-06-14T12:06:43,491][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [lang-mustache]
[2018-06-14T12:06:43,491][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [lang-painless]
[2018-06-14T12:06:43,491][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [mapper-extras]
[2018-06-14T12:06:43,491][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [parent-join]
[2018-06-14T12:06:43,491][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [percolator]
[2018-06-14T12:06:43,491][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [rank-eval]
[2018-06-14T12:06:43,491][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [reindex]
[2018-06-14T12:06:43,491][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [repository-url]
[2018-06-14T12:06:43,492][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [transport-netty4]
[2018-06-14T12:06:43,492][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded module [tribe]
[2018-06-14T12:06:43,492][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [ingest-geoip]
[2018-06-14T12:06:43,492][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [ingest-user-agent]
[2018-06-14T12:06:43,492][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [x-pack-core]
[2018-06-14T12:06:43,493][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [x-pack-deprecation]
[2018-06-14T12:06:43,493][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [x-pack-graph]
[2018-06-14T12:06:43,493][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [x-pack-logstash]
[2018-06-14T12:06:43,493][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [x-pack-ml]
[2018-06-14T12:06:43,493][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [x-pack-monitoring]
[2018-06-14T12:06:43,493][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [x-pack-security]
[2018-06-14T12:06:43,494][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [x-pack-upgrade]
[2018-06-14T12:06:43,494][INFO ][o.e.p.PluginsService ] [zXCixBy] loaded plugin [x-pack-watcher]
[2018-06-14T12:06:50,083][INFO ][o.e.x.m.j.p.l.CppLogMessageHandler] [controller/204] [Main.cc@128] controller (64 bit): Version 6.2.4 (Build 524e7fe231abc1) Copyright (c) 2018 Elasticsearch BV
[2018-06-14T12:06:52,790][INFO ][o.e.d.DiscoveryModule ] [zXCixBy] using discovery type [zen]
[2018-06-14T12:06:54,928][INFO ][o.e.n.Node ] initialized
[2018-06-14T12:06:54,929][INFO ][o.e.n.Node ] [zXCixBy] starting ...
[2018-06-14T12:06:55,257][INFO ][o.e.t.TransportService ] [zXCixBy] publish_address {172.17.0.3:9300}, bound_addresses {0.0.0.0:9300}
[2018-06-14T12:06:55,291][INFO ][o.e.b.BootstrapChecks ] [zXCixBy] bound or publishing to a non-loopback address, enforcing bootstrap checks
[2018-06-14T12:06:58,368][INFO ][o.e.c.s.MasterService ] [zXCixBy] zen-disco-elected-as-master ([0] nodes joined), reason: new_master {zXCixBy}{zXCixByNTHSbNB09Bx5L-A}{rZ-BGNgCQ6-KX2Bfu3epdg}{172.17.0.3}{172.17.0.3:9300}{ml.machine_memory=2096066560, ml.max_open_jobs=20, ml.enabled=true}
[2018-06-14T12:06:58,379][INFO ][o.e.c.s.ClusterApplierService] [zXCixBy] new_master {zXCixBy}{zXCixByNTHSbNB09Bx5L-A}{rZ-BGNgCQ6-KX2Bfu3epdg}{172.17.0.3}{172.17.0.3:9300}{ml.machine_memory=2096066560, ml.max_open_jobs=20, ml.enabled=true}, reason: apply cluster state (from master [master {zXCixBy}{zXCixByNTHSbNB09Bx5L-A}{rZ-BGNgCQ6-KX2Bfu3epdg}{172.17.0.3}{172.17.0.3:9300}{ml.machine_memory=2096066560, ml.max_open_jobs=20, ml.enabled=true} committed version [1] source [zen-disco-elected-as-master ([0] nodes joined)]])
[2018-06-14T12:06:58,436][INFO ][o.e.x.s.t.n.SecurityNetty4HttpServerTransport] [zXCixBy] publish_address {172.17.0.3:9200}, bound_addresses {0.0.0.0:9200}
[2018-06-14T12:06:58,436][INFO ][o.e.n.Node ] [zXCixBy] started
[2018-06-14T12:06:58,514][INFO ][o.e.g.GatewayService ] [zXCixBy] recovered [0] indices into cluster_state
[2018-06-14T12:06:59,617][INFO ][o.e.l.LicenseService ] [zXCixBy] license [25bb1a8c-40c7-4278-aafc-a867b5454666] mode [basic] - valid
[2018-06-14T12:07:05,751][INFO ][o.e.c.m.MetaDataCreateIndexService] [zXCixBy] [.monitoring-es-6-2018.06.14] creating index, cause [auto(bulk api)], templates [.monitoring-es], shards [1]/[0], mappings [doc]
[2018-06-14T12:07:06,767][INFO ][o.e.c.r.a.AllocationService] [zXCixBy] Cluster health status changed from [YELLOW] to [GREEN] (reason: [shards started [[.monitoring-es-6-2018.06.14][0]] ...]).
It's ok. I've figured it out
I'll get my coat.
PS: Thanks for all your help. This is totally the best way to do it, and way better than what we were previously doing with the embedded node.
For the record, could you share your findings here? That could help other readers.
I'm glad you are agreeing on that!
Sure, my problem was that I was expecting the ES cluster to be called elasticsearch, when actually the dockerised cluster is called: docker-cluster.
If you specify the wrong cluster name in your TransportClient connection settings, it won't connect. If you need to confirm it, just curl -XGET localhost:[REST PORT] and see what the cluster_name property is.
TBH, I'm just glad I can still integration test my stuff without having to manage an integration-testing ES cluster myself as well.
Great! I added some documentation based on that. Thanks!
Is there currently a way to tell the container which port to map to? One of my tests checks that a reconnection is made if lost at any point.
I'm currently testing this by stopping and starting the container, but when it comes back up again, the ports have all changed. In reality that wouldn't happen.
Any ideas?
Also, if I do elasticsearch.getContainer().stop() and elasticsearch.getContainer().start() inside a test, this happens when the test exits:
[dockerjava-netty-1-5] ERROR com.github.dockerjava.core.async.ResultCallbackTemplate - Error during callback
com.github.dockerjava.api.exception.NotFoundException: {"message":"No such container: 5cd80164de9986021cc59442425380afc2eab9b7efc669c9841674ca0dc02d23"}
I'm assuming when the @Rule ElasticsearchResource is torn down it assumes that the reference to the container it obtained when starting up is still the same...?
I believe you'd like to have that?
In that case I'd not use @Rule annotation but control all that manually.
Like what I did here:
Yes! (also for Transport port, obviously
