Connecting Filebeat from local machine to existing logstash pipeline
I'm attempting to push logs from my local machine using Filebeats through an existing logstash collector node to an existing elastic index. Here is my filebeat.yml file:
filebeat.inputs:
- type: log
  enabled: true
  paths:
    - C:\Users\ElamR\Documents\ELK\*.log
  exclude_lines: ['^10\.55\.191\..*"GET \/status.*"LTM-Monitor" "-"$']
  fields_under_root: true
  fields:
    secret: "**************"
output.logstash:
  hosts: ["log-evt-dms.els-gp.icp.infineon.com:9889"]
When I run
.\filebeat.exe setup -e
I get the following error message:
{"log.level":"info","@timestamp":"2023-04-25T14:22:50.821-0400","log.origin":{"file.name":"instance/beat.go","file.line":724},"message":"Home path: [C:\\Program Files\\Filebeat] Config path: [C:\\Program Files\\Filebeat] Data path: [C:\\Program Files\\Filebeat\\data] Logs path: [C:\\Program Files\\Filebeat\\logs]","service.name":"filebeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2023-04-25T14:22:50.824-0400","log.origin":{"file.name":"instance/beat.go","file.line":732},"message":"Beat ID: 8898858b-16d4-44c5-80db-fd1668d81ca3","service.name":"filebeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2023-04-25T14:22:50.825-0400","log.logger":"beat","log.origin":{"file.name":"instance/beat.go","file.line":1096},"message":"Beat info","service.name":"filebeat","system_info":{"beat":{"path":{"config":"C:\\Program Files\\Filebeat","data":"C:\\Program Files\\Filebeat\\data","home":"C:\\Program Files\\Filebeat","logs":"C:\\Program Files\\Filebeat\\logs"},"type":"filebeat","uuid":"8898858b-16d4-44c5-80db-fd1668d81ca3"},"ecs.version":"1.6.0"}}
{"log.level":"info","@timestamp":"2023-04-25T14:22:50.825-0400","log.logger":"beat","log.origin":{"file.name":"instance/beat.go","file.line":1105},"message":"Build info","service.name":"filebeat","system_info":{"build":{"commit":"a8dbc6c06381f4fe33a5dc23906d63c04c9e2444","libbeat":"8.7.0","time":"2023-03-23T00:44:06.000Z","version":"8.7.0"},"ecs.version":"1.6.0"}}
{"log.level":"info","@timestamp":"2023-04-25T14:22:50.825-0400","log.logger":"beat","log.origin":{"file.name":"instance/beat.go","file.line":1108},"message":"Go runtime info","service.name":"filebeat","system_info":{"go":{"os":"windows","arch":"amd64","max_procs":8,"version":"go1.19.7"},"ecs.version":"1.6.0"}}
{"log.level":"info","@timestamp":"2023-04-25T14:22:50.843-0400","log.logger":"beat","log.origin":{"file.name":"instance/beat.go","file.line":1114},"message":"Host info","service.name":"filebeat","system_info":{"host":{"architecture":"x86_64","boot_time":"2023-04-21T08:57:34-04:00","name":"ISCN5CG2236JNF","ip":["fe80::5286:1845:cf6e:ea26","fe80::f3b5:e382:39c8:be9b","fe80::99ab:7d7c:1fae:4af6","10.53.113.81","fe80::55d9:3e7:c40f:1690","::1","127.0.0.1"],"kernel_version":"10.0.19041.2846 (WinBuild.160101.0800)","mac":["5c:60:ba:38:8d:08","70:a8:d3:c8:29:19","70:a8:d3:c8:29:18","70:a8:d3:c8:29:1c"],"os":{"type":"windows","family":"windows","platform":"windows","name":"Windows 10 Enterprise","version":"10.0","major":10,"minor":0,"patch":0,"build":"19045.2846"},"timezone":"EDT","timezone_offset_sec":-14400,"id":"ae50890d-1487-44df-ba9c-321208203cba"},"ecs.version":"1.6.0"}}
{"log.level":"info","@timestamp":"2023-04-25T14:22:50.843-0400","log.logger":"beat","log.origin":{"file.name":"instance/beat.go","file.line":1143},"message":"Process info","service.name":"filebeat","system_info":{"process":{"cwd":"C:\\Program Files\\Filebeat","exe":"C:\\Program Files\\Filebeat\\filebeat.exe","name":"filebeat.exe","pid":11884,"ppid":16124,"start_time":"2023-04-25T14:22:50.698-0400"},"ecs.version":"1.6.0"}}
{"log.level":"info","@timestamp":"2023-04-25T14:22:50.844-0400","log.origin":{"file.name":"instance/beat.go","file.line":297},"message":"Setup Beat: filebeat; Version: 8.7.0","service.name":"filebeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2023-04-25T14:22:53.244-0400","log.logger":"publisher","log.origin":{"file.name":"pipeline/module.go","file.line":113},"message":"Beat name: ISCN5CG2236JNF","service.name":"filebeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2023-04-25T14:22:53.245-0400","log.logger":"modules","log.origin":{"file.name":"fileset/modules.go","file.line":120},"message":"Enabled modules/filesets: ","service.name":"filebeat","ecs.version":"1.6.0"}
{"log.level":"warn","@timestamp":"2023-04-25T14:22:53.245-0400","log.origin":{"file.name":"beater/filebeat.go","file.line":175},"message":"Filebeat is unable to load the ingest pipelines for the configured modules because the Elasticsearch output is not configured/enabled. If you have already loaded the ingest pipelines or are using Logstash pipelines, you can ignore this warning.","service.name":"filebeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2023-04-25T14:22:53.246-0400","log.origin":{"file.name":"instance/beat.go","file.line":1071},"message":"Exiting: index management requested but the Elasticsearch output is not configured/enabled","service.name":"filebeat","ecs.version":"1.6.0"}
Any help I could get to iron this out would be appreciatied. I am doing this to push data to a currently empty test cluster to enable the testing of a script before pushing it to production.
This is for importing dashboards in Kibana, create template and ingest pipelines in ES.
To run FB:
.\filebeat -c c:\somepath\filebeat.yml -e
Thanks! Was definitely a noob question but all of the Elastic documentation for installing and running filebeats for the first time is geared towards setting up a new pipeline as well I suppose, makes sense but I didn't realize that initially. I need to read more carefully.
