Data.path problem
I installed logstash in a different path of default path. When I'm trying to launch more than 1 pipeline I'm getting the following error:
Logstash could not be started because there is already another instance using the configured data directory. If you wish to run multiple instances, you must change the "path.data" setting.
I have configured the logstash.yml with this lines:
http.host: "0.0.0.0"
log.level: debug
path.data: /aplicaciones/logstash/data/
path.config: /aplicaciones/logstash/config/
Can sombody help me?
Thanks a lot
Are you remembering to tell logstash about the new logstash.yml file when you launch it?
/path/to/logstash/bin/logstash --path.settings /aplicaciones/logstash/logstash.yml
You have to define the second logstash.yml settings file manually otherwise it will look at the $LS_SETTING_DIR environment variable.
