Docker and Kubernetes problem with connecting to Elasticsearch
Where I can find configuration documentation for docker images for:
docker.elastic.co/app-search/app-search:7.5.1 ? I am not sure how to configure app search docker image to connect to ES within Kubernetes cluster.
I am getting following error on startup:
Blockquote
Error: App Search is unable to connect to Elasticsearch. Ensure a healthy Elasticsearch cluster is running at http://quickstart-es-default:9200 for user elastic.
Blockquote
The http://quickstart-es-default:9200 is correct address and I can successfully do following:
curl -u "elastic:somepassword" -k "https://quickstart-es-default:9200" from any node in the cluster.
thanks
Solved! Had to configure app search to use ssl (ca, ce, and key).
