Duplicating message parts in Elastic dashboard
I had shipped log to ES with the integration of filebeat and logstash.
This is my logstash.conf
# Read input from filebeat by listening to port 5044 on which filebeat will send the data
    beats {
	    type => "test"
        port => "5044"
  #If log line contains tab character followed by 'at' then we will tag that entry as stacktrace
  if [fields][level] == "info" {
    grok {
      match => {"message" => ["(?m)%{TIMESTAMP_ISO8601:timestamp} - %{NOTSPACE:orgCode} - %{GREEDYDATA:message}"]}
	  #break_on_match => true
      add_tag => ["cms-info"]
	  tag_on_failure => ["_grokparsefailure-cms-info"]
  stdout {
    codec => rubydebug
  # Sending properly parsed log events to elasticsearch
    hosts => ["https://xxxxxxxx.us-east-1.aws.found.io:443"]
    index => "%{[fields][service-name]}-%{[fields][env]}-%{[fields][application]}-%{[fields][level]}-%{+yyyy.MM.dd}"
    user => "elastic"
    password => "xxxxxx"
This is my log message
"2019-10-29 21:57:16.9884 - yyyyy - Generating [item settings cloudfront item links] for asset : 137909"
But in my ES board showsed duplicating message parts. like following
How can I solve this?
You have not specified the overwrite parameter, so the rest of the message is appended to the message field instead of replacing it.
On an unrelated note, this looks like a pattern that could result in a lot of very small indices and shards. This can cause performance and stability problems down the line, so I would recommend you reconsider this approach. See this blog post for details.
Thanks it works !!
