Field overwrite is not working
I want to only keep a certain part of a syslog message as the message.
    udp {
        port => "514"
        type => "syslog-cisco"
    tcp {
        port => "514"
    grok {
        patterns_dir => ["../patterns"]
        match => [
            "message", "%{SYSLOG5424PRI}(%{NUMBER:log_sequence#})?:( %{NUMBER}:)? %{CISCOTIMESTAMPTZ:log_date}: %%{SYSLOGPROG:facility}-%{INT:severity_level}-%{SYSLOGPROG:facility_mnemonic}: %{GREEDYDATA:message}",
            "message", "%{SYSLOG5424PRI}(%{NUMBER:log_sequence#})?:( %{NUMBER}:)? %{CISCOTIMESTAMPTZ:log_date}: %%{SYSLOGPROG:facility}-%{SYSLOGPROG:facility_sub}-%{INT:severity_level}-%{SYSLOGPROG:facility_mnemonic}: %{GREEDYDATA:message}"
        overwrite => [ "message" ]
        add_tag => [ "cisco-ios" ]
        add_tag => [ "cisco" ]
        remove_field => [ "syslog5424_pri", "@version" ]
    } # grok
    if "cisco-ios" not in [tags] {
        mutate {
            remove_tag => [ "_grokparsefailure" ]
        grok {
            match => [
                "message", "%{SYSLOG5424PRI}(%{HOSTNAME:hostname})?:( \*%{SYSLOGPROG:facility}:) (%{CISCOTIMESTAMP:log_date}:) (%%{SYSLOGPROG:facility_sub}:) %{GREEDYDATA: message}"
            add_tag => [ "cisco-wlc" ]
            remove_field => [ "@version", "program" ]
        } # grok
    } # if
} # filter
        hosts => ["localhost:9200"]
        index => "network-%{+YYYY.MM.dd}"
In the firstt grok{} it works, and only %{GREEDYDATA:message} gets assigned to message in the overwrite, but for some reason, it is not happening with the second one.
Why?
EDIT:
This is what the syslog message for the second grok{} looks like:
<182>HOST001: *radiusTransportThread: Nov 10 10:02:22.149: %AAA-6-RADIUS_IN_GLOBAL_LIST: [PA]radius_db.c:426 RADIUS server 172.20.1.84:1813 activated in global list
You seem to have a space in there just before message. Is that causing this?
