Filebeat and Multiline Problem
I'm using Filbeat 1.2.3 on Windows and seeing a problem with multiline and would appreciate someone pointing out what I must be doing wrong.
I'm sending my Filebeat events to Logstash. Here are the relevant configs:-
Filebeat target file content:
lineone
linetwo
linethree
linefour
linefive
Filebeat.yml
filebeat:
prospectors:
input_type: log
paths:
- "E:/target/*.txt"
multiline:
pattern: 'linethree'
match: before
logging:
files:
rotateeverybytes: 10485760
output:
logstash:
hosts: ["xxxxxx:6379"]
index: filebeat
Logstash config file:
beats {
	port => 6379
# Filters go here as required
stdout {
    codec => rubydebug
What I get (on the Logstash stdout):
"message" => "linetwo",
"@version" => "1",
"@timestamp" => "2016-08-24T13:41:13.849Z",
"count" => 1,
"fields" => nil,
"beat" => {
"hostname" => "xxxxxx",
"name" => "xxxxxx"
"type" => "log",
"input_type" => "log",
"offset" => 32574,
"source" => "E:\target\sampledata.txt",
"host" => "xxxxxx",
"tags" => [
[0] "beats_input_codec_plain_applied"
"message" => "linethree",
"@version" => "1",
"type" => "log",
"fields" => nil,
"offset" => 32583,
"count" => 1,
"beat" => {
"name" => "xxxxxx"
"host" => "xxxxxx",
"tags" => [
"message" => "linefour",
"@version" => "1",
"count" => 1,
"type" => "log",
"offset" => 32594,
"fields" => nil,
"beat" => {
"name" => "xxxxxx"
"host" => "xxxxxx",
"tags" => [
"message" => "linefive",
"@version" => "1",
"offset" => 32604,
"type" => "log",
"count" => 1,
"beat" => {
"name" => "xxxxxx"
"fields" => nil,
"host" => "xxxxxx",
"tags" => [
My question, is why is line three "linethree" not being appended to line two "linetwo"? Is that not what should happen?
can you correctly format (use </> button) the config files? YAML (the config file format) is sensitive to indentation and characters used. It seems multiline is not applied at all, which might a problem due to faulty intendation (use 2 spaces per level + no tabs).
@steffens
Thank you - yes, it was a broken line in the YAML. All working now :slight_smile:
