Filebeat Index Issue - template pattern / name
Hey Guys
I'm trying to set my index, in filebeat, this is my current config:
output.elasticsearch:
  hosts: ["192.168.1.199:9200"]
  setup.template.name: "desktop"
  setup.template.pattern: "desktop-*"
  index: "desktop-%{[beat.version]}-%{+yyyy.MM.dd}"
  indices:
    - index: "critical-%{[beat.version]}-%{+yyyy.MM.dd}"
      when.contains:
        message: "CRITICAL"
    - index: "error-%{[beat.version]}-%{+yyyy.MM.dd}"
      when.contains:
        message: "ERR"
  # Optional protocol and basic auth credentials.
  #protocol: "https"
  username: "elastic"
  password: "blah"
  timeout: 180
  bulk_max_size: 2
I made to sure to add the template with:
filebeat export template > filebeat.template.json
curl -XPUT --user elastic:blah -H 'Content-Type: application/json' http://192.168.1.199:9200/_template/desktop -d@filebeat.template.json
but when I start filebeat (service filebeat start), I get:
Exiting: setup.template.name and setup.template.pattern have to be set if index name is modified.
I'm on Ubuntu 17.10 and my ELK is on Ubuntu 18.04, can anyone see what I'm doing wrong?
D
Your config seems to be incorrect. setup.template.* should not go under output.elasticsearch. It stands in the root of the config, as seen here:
  indices:
      when.contains:
        message: "CRITICAL"
      when.contains:
        message: "ERR"
  #protocol: "https"
  username: "elastic"
  password: "blah"
  timeout: 180
  bulk_max_size: 2
That was the issue :slight_smile: Thanks!
