[filebeat]Suspect Redis connection pool configuration issue causing discrepancy between maximum connection settings and actual results
Description:
I am experiencing an issue with the maximum connection settings in Redis not matching the expected behavior. I suspect that there might be a problem with the Redis connection pool configuration.
Specifically, I am using Filebeat to collect Redis slow logs, but the maximum number of connections that are being established does not align with the settings I have configured. This has led me to suspect that there might be an issue with the connection pool parameters for Redis.
Could someone please help me troubleshoot this issue? I would like to understand if my Redis connection pool configuration is incorrect or if there are any other potential reasons for this discrepancy.
Thank you!
