Filebeats Sending Data to the Wrong index (ignoring .yml config and using default index)
I'm testing a filebeats indexing of JSON content created with wireshark.
I have the filebeat.yml configured as below, but the logs keep going to the default filebeats index, (filebeat-7.5.2-2020.01.27-000001).
Can someone point me on the right direction?
Thank you!
filebeat.inputs:
  • type: log
    paths:
    • "c:/sample/packets6.json"
      document_type: "pcap_file"
      json.keys_under_root: true
processors:
  • drop_event:
    when:
    equals:
    index._type: "pcap_file"
output.elasticsearch:
index: "packets-%{+yyyy-MM-dd}"
hosts: ["10.1.30.104:9200"]
path: "packets-test"
setup.template.name: "packets-"
setup.template.pattern: "packets-
setup.template.enabled: false
Debug logging config.
logging.level: debug
logging.selectors: ['*']
Bringing the thread up to try to get some help
Can you validate your yaml here => http://www.yamllint.com/
I pasted it over and it said it was "valid"
Did you manually load the template named "packets-"? coz if its not there, by default, filebeat template will be used.
Yes, I manually created a template that applies to the pattern packets-*.
But in any case the data should be getting to the right index right? just using the wrong template even if I had not crated the template?
Could u please include ur template? Bcoz I can see u put “packet-“ as template name in filebeat config
"packets" : {
"order" : 0,
"index_patterns" : [
"packets-*"
"settings" : { },
"mappings" : {
"dynamic" : "false",
"properties" : {
"layers" : {
"properties" : {
"udp" : {
"properties" : {
"udp_udp_srcport" : {
"type" : "integer"
"udp_udp_dstport" : {
"type" : "integer"
"ip" : {
"properties" : {
"ip_ip_src" : {
"type" : "ip"
"ip_ip_dst" : {
"type" : "ip"
"frame" : {
"properties" : {
"frame_frame_len" : {
"type" : "long"
"frame_frame_protocols" : {
"type" : "keyword"
"timestamp" : {
"type" : "date"
"aliases" : { }
hi @guibarati,
in your filebeat config, you have this line:
but your template is named "packets" :smiley:
Hi @inhinyera16, I've changed the setup.template.name to "packets" but it didn't have an effect.
I changed my index output to "packets-test" on my yml file and started receiving the following message:
Failed to connect to backoff(elasticsearch(http://10.1.30.104:9200/packets-test)): 404 Not Found: {"error":{"root_cause":[{"type":"index_not_found_exception"
Then I manually created the index, but got another error and the index is not being populated with data:
elasticsearch/client.go:771 GET http://10.1.30.104:9200/packets-test/_xpack?human=false
licenser/elastic_fetcher.go:105 Received 'Method Not allowed' (405) response from server, fallback to OSS license
