Filltering messages by tags problem with some messages
So I have a problem with logstash:
some messages are being sent to default index:(below is the message that went into 'default' index.
  "_index": "default-logs-2018.10.10",
  "_type": "doc",
  "_id": "MioyXmYBMkEJhrYr2PRg",
  "_score": 1,
  "_source": {
    "source": "/var/log/messages",
    "host": {
      "name": "serverx"
    "beat": {
      "version": "6.4.2",
      "name": "serverx",
      "hostname": "serverx"
    "@version": "1",
    "offset": 2767233,
    "fields": {
      "document_type": "syslog"
    "@timestamp": "2018-10-10T13:37:56.000Z",
    "system": {
      "syslog": {
        "program": "root",
        "timestamp": "Oct 10 15:37:56",
        "hostname": "serverx",
        "message": "172.30.11.18 - - [10/Oct/2018:15:37:56 +0200] \"GET /something HTTP/1.1\" 200 3839 \"-\" \"Java/1.8.0_152\""
    "tags": [
      "syslog",
      "prod",
      "beats_input_codec_plain_applied"
  "fields": {
    "@timestamp": [
It happens only with syslog logs.
This is relevant part of logstash
if "syslog" in [tags] {
      grok {
        match => { "message" => ["%{SYSLOGTIMESTAMP:[system][syslog][timestamp]} %{SYSLOGHOST:[system][syslog][hostname]} %{DATA:[system][syslog][program]}(?:\[%{POSINT:[system][syslog][pid]}\])?: %{GREEDYMULTILINE:[system][syslog][message]}"] }
        pattern_definitions => { "GREEDYMULTILINE" => "(.|\n)*" }
        remove_field => "message"
      date {
        match => [ "[system][syslog][timestamp]", "MMM  d HH:mm:ss", "MMM dd HH:mm:ss" ]
        user => logstash
        password => logstash
        ssl => true
        hosts => ["https://localhost:9200"]
        cacert => '/etc/logstash/esnode.pem'
        sniffing => false
        manage_template => false
        index => "system-logs-%{+YYYY.MM.dd}"
    else {
        user => logstash
        ssl => true
        sniffing => false
        index => "default-logs-%{+YYYY.MM.dd}"
This is filebeats conf:
- input_type: log
  paths:
     - /var/log/messages*
     - /var/log/syslog*
  fields:
    document_type: syslog
  multiline.pattern: "^\\s"
  multiline.match: after
  exclude_files: [".gz$"]
  tags: ["syslog", "prod"]
Same amount of messages goes to defaults-logs index and system-logs index.
Actually it seems like other messages are also affected not only system logs...
