Fitebeat 6.3.1 system module issue
That was the last line in the log you posted a couple of comments above. That seems to indicate that the filebeat-6.3.1-system-syslog-pipeline ingest pipeline was loaded up.
If you run curl -XGET "http://localhost:9200/_ingest/pipeline/file*syslog* now, do you still not see the timezone setting in the date processor in that pipeline?
curl -XGET "http://localhost:9200/_ingest/pipeline/file*syslog*"
{"filebeat-6.3.1-system-syslog-pipeline":{"description":"Pipeline for parsing Syslog messages.","processors":[{"grok":{"ignore_missing":true,"field":"message","patterns":["%{SYSLOGTIMESTAMP:system.syslog.timestamp} %{SYSLOGHOST:system.syslog.hostname} %{DATA:system.syslog.program}(?:\[%{POSINT:system.syslog.pid}\])?: %{GREEDYMULTILINE:system.syslog.message}","%{SYSLOGTIMESTAMP:system.syslog.timestamp} %{GREEDYMULTILINE:system.syslog.message}"],"pattern_definitions":{"GREEDYMULTILINE":"(.|\n)"}}},{"remove":{"field":"message"}},{"date":{"field":"system.syslog.timestamp","target_field":"@timestamp","formats":["MMM d HH:mm:ss","MMM dd HH:mm:ss"],"ignore_failure":true}}],"on_failure":[{"set":{"field":"error.message","value":"{{ _ingest.on_failure_message }}"}}]},"filebeat-6.3.2-system-syslog-pipeline":{"description":"Pipeline for parsing Syslog messages.","processors":[{"grok":{"field":"message","patterns":["%{SYSLOGTIMESTAMP:system.syslog.timestamp} %{SYSLOGHOST:system.syslog.hostname} %{DATA:system.syslog.program}(?:\[%{POSINT:system.syslog.pid}\])?: %{GREEDYMULTILINE:system.syslog.message}","%{SYSLOGTIMESTAMP:system.syslog.timestamp} %{GREEDYMULTILINE:system.syslog.message}"],"pattern_definitions":{"GREEDYMULTILINE":"(.|\n)"},"ignore_missing":true}},{"remove":{"field":"message"}},{"date":{"field":"system.syslog.timestamp","target_field":"@timestamp","formats":["MMM d HH:mm:ss","MMM dd HH:mm:ss"],"ignore_failure":true}}],"on_failure":[{"set":{"field":"error.message","value":"{{ _ingest.on_failure_message }}"}}]}}
Please share me the filebeat.yml and "/etc/filebeat/modules/system.yml" config file; Just wanted to verify.
Why it is not working for me. I have not made changes to config file. Just made an entry[ var.convert_timezone: true] change to /etc/filebeat/modules/system.yml
Please share me the filebeat.yml and "/etc/filebeat/modules/system.yml" config files;
As you mentioned you are good with system modules, just wanted to compare the config files. I have not made changes to config file. Just made an entry[ var.convert_timezone: true] change to /etc/filebeat/modules/system.yml
- module: system
  # Syslog
  syslog:
    enabled: true
    # Set custom paths for the log files. If left empty,
    # Filebeat will choose the paths depending on your OS.
    #var.paths:
    # Convert the timestamp to UTC. Requires Elasticsearch >= 6.1.
  # Authorization logs
  auth:
    enabled: true
    #var.paths:
File: /var/lib/filebeat/registry
[{"source":"/var/log/fontconfig.log","offset":1595,"timestamp":"2018-07-27T04:39:33.039794035-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":55457,"device":51713}},{"source":"/var/log/kern.log","offset":0,"timestamp":"2018-07-27T04:39:33.043196589-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":6554,"device":51713}},{"source":"/var/log/mail.log","offset":0,"timestamp":"2018-07-27T04:39:33.046297732-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":6542,"device":51713}},{"source":"/var/log/alternatives.log","offset":0,"timestamp":"2018-07-27T04:39:33.049354647-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":6560,"device":51713}},{"source":"/var/log/cloud-init-output.log","offset":1830858,"timestamp":"2018-07-27T04:39:33.052581509-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":51060,"device":51713}},{"source":"/var/log/cloud-init.log","offset":255061,"timestamp":"2018-07-27T04:39:33.055793968-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":51059,"device":51713}},{"source":"/var/log/dpkg.log","offset":33763,"timestamp":"2018-07-27T04:39:33.059004416-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":6556,"device":51713}},{"source":"/var/log/auth.log","offset":195840,"timestamp":"2018-07-27T04:39:33.131430975-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":5317,"device":51713}},{"source":"/var/log/syslog.1","offset":498236,"timestamp":"2018-07-27T04:39:33.145264877-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":4955,"device":51713}},{"source":"/var/log/syslog","offset":95634,"timestamp":"2018-07-27T04:39:33.149061775-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":4185,"device":51713}},{"source":"/var/log/ansible.log","offset":1524521,"timestamp":"2018-07-27T04:39:33.065642651-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":51200,"device":51713}},{"source":"/var/log/aptitude","offset":0,"timestamp":"2018-07-14T07:30:40.4573387-07:00","ttl":-2,"type":"log","meta":null,"FileStateOS":{"inode":6552,"device":51713}},{"source":"/var/log/auth.log.1","offset":0,"timestamp":"2018-07-27T04:39:33.135059822-07:00","ttl":-1,"type":"log","meta":null,"FileStateOS":{"inode":5316,"device":51713}},{"source":"/var/log/syslog.7.gz","offset":23413,"timestamp":"2018-07-27T03:36:26.344859976-07:00","ttl":-2,"type":"log","meta":null,"FileStateOS":{"inode":4590,"device":51713}},{"source":"/var/log/syslog.2.gz","offset":22455,"timestamp":"2018-07-27T03:36:26.35104531-07:00","ttl":-2,"type":"log","meta":null,"FileStateOS":{"inode":4895,"device":51713}},{"source":"/var/log/syslog.3.gz","offset":23457,"timestamp":"2018-07-27T03:36:26.331978977-07:00","ttl":-2,"type":"log","meta":null,"FileStateOS":{"inode":6436,"device":51713}},{"source":"/var/log/syslog.4.gz","offset":23302,"timestamp":"2018-07-27T03:36:26.334868819-07:00","ttl":-2,"type":"log","meta":null,"FileStateOS":{"inode":5535,"device":51713}},{"source":"/var/log/syslog.5.gz","offset":23858,"timestamp":"2018-07-27T03:36:26.338248729-07:00","ttl":-2,"type":"log","meta":null,"FileStateOS":{"inode":2967,"device":51713}},{"source":"/var/log/syslog.6.gz","offset":24364,"timestamp":"2018-07-27T03:36:26.341475422-07:00","ttl":-2,"type":"log","meta":null,"FileStateOS":{"inode":2788,"device":51713}},{"source":"/var/log/alternatives.log","offset":0,"timestamp":"2018-07-27T04:39:33.068791974-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":6560,"device":51713}},{"source":"/var/log/fontconfig.log","offset":1595,"timestamp":"2018-07-27T04:39:33.072163462-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":55457,"device":51713}},{"source":"/var/log/mail.log","offset":0,"timestamp":"2018-07-27T04:39:33.075215686-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":6542,"device":51713}},{"source":"/var/log/cloud-init.log","offset":255061,"timestamp":"2018-07-27T04:39:33.078431985-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":51059,"device":51713}},{"source":"/var/log/dpkg.log","offset":33763,"timestamp":"2018-07-27T04:39:33.081763426-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":6556,"device":51713}},{"source":"/var/log/kern.log","offset":0,"timestamp":"2018-07-27T04:39:33.085154411-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":6554,"device":51713}},{"source":"/var/log/ansible.log","offset":1524521,"timestamp":"2018-07-27T04:39:33.090848975-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":51200,"device":51713}},{"source":"/var/log/auth.log","offset":198711,"timestamp":"2018-07-27T04:39:33.216345544-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":5317,"device":51713}},{"source":"/var/log/cloud-init-output.log","offset":1830858,"timestamp":"2018-07-27T04:39:33.097910848-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":51060,"device":51713}},{"source":"/var/log/syslog","offset":0,"timestamp":"2018-07-27T04:39:33.194075037-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":4185,"device":51713}},{"source":"/var/log/syslog.1","offset":0,"timestamp":"2018-07-27T04:39:33.204599189-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":4955,"device":51713}},{"source":"/var/log/auth.log.1","offset":0,"timestamp":"2018-07-27T04:39:33.230591066-07:00","ttl":-1,"type":"log","meta":{},"FileStateOS":{"inode":5316,"device":51713}}]
I observed only prospector logs[/var/log/*.log] are coming into elasticsearch, not system module logs.
filebeat logs:
|2018-07-27T04:29:03.417-0700|INFO|log/harvester.go:228|Harvester started for file: /var/log/auth.log|
|2018-07-27T04:29:03.427-0700|INFO|log/input.go:113|Configured paths: [/var/log/auth.log* /var/log/secure*]|
|2018-07-27T04:29:03.433-0700|INFO|log/input.go:113|Configured paths: [/var/log/messages* /var/log/syslog*]|
|2018-07-27T04:29:03.433-0700|INFO|crawler/crawler.go:82|Loading and starting Inputs completed. Enabled inputs: 1|
|2018-07-27T04:29:03.433-0700|INFO|cfgfile/reload.go:122|Config reloader started|
|2018-07-27T04:29:03.441-0700|ERROR|fileset/factory.go:72|Error creating input: Can only start an input when all related states are finished: {Id:0-5317-51713 Finished:false Fileinfo:0xc4204ae5b0 Source:/var/log/auth.log Offset:197900 Timestamp:2018-07-27 04:29:03.430147214 -0700 PDT m=+0.080186641 TTL:-1ns Type:log Meta:map[] FileStateOS:5317-51713}|
|2018-07-27T04:29:03.441-0700|ERROR|cfgfile/reload.go:201|Unable to create runner due to error: Can only start an input when all related states are finished: {Id:0-5317-51713 Finished:false Fileinfo:0xc4204ae5b0 Source:/var/log/auth.log Offset:197900 Timestamp:2018-07-27 04:29:03.430147214 -0700 PDT m=+0.080186641 TTL:-1ns Type:log Meta:map[] FileStateOS:5317-51713}|
|2018-07-27T04:29:03.441-0700|INFO|cfgfile/reload.go:214|Loading of config files completed.|
|2018-07-27T04:29:04.420-0700|INFO|elasticsearch/client.go:690|Connected to Elasticsearch version 6.2.4|
|2018-07-27T04:29:04.422-0700|INFO|template/load.go:73|Template already exists and will not be overwritten.|
recent logs:
|2018-07-27T05:30:57.451-0700|ERROR|fileset/factory.go:69|Error creating prospector: Can only start a prospector when all related states are finished: {Id: Finished:false Fileinfo:0xc4204449c0 Source:/var/log/auth.log Offset:0 Timestamp:2018-07-27 05:30:57.447433007 -0700 PDT m=+0.032391182 TTL:-1ns Type:log FileStateOS:5317-51713}|
|2018-07-27T05:30:57.451-0700|ERROR|cfgfile/reload.go:206|Unable to create runner due to error: Can only start a prospector when all related states are finished: {Id: Finished:false Fileinfo:0xc4204449c0 Source:/var/log/auth.log Offset:0 Timestamp:2018-07-27 05:30:57.447433007 -0700 PDT m=+0.032391182 TTL:-1ns Type:log FileStateOS:5317-51713}|
I noticed that in the output from GET _ingest/pipeline/file*syslog*, you are actually getting back two ingest pipelines, one named filebeat-6.3.1-system-syslog-pipeline and the other named filebeat-6.3.2-system-syslog-pipeline.
This indicates that you are running filebeat-6.3.1 and filebeat-6.3.2 in parallel.
Also in an earlier post you mentioned that you have installed filebeat on 50+ servers.
For debugging this issue could you temporarily stop all your 50+ filebeat instances? Then follow the steps from Fitebeat 6.3.1 system module issue using only one filebeat instance. Then please post the results of those steps, specifically steps 4 and 5.
performed those steps:
Filebeat log:
2018-07-27T11:06:28.684-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbecef5a7a8b3c900, ext:93243359275, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"host":common.MapStr{"name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "source":"/var/log/auth.log", "offset":528450, "message":"Jul 27 11:06:22 mouli-i-038f2e3e573d951b6 sshd[3691]: Close session: user rdmon from 2600:1f18:2270:741e:3f2a:54ab:3f89:5fe9 port 49894 id 0", "input":common.MapStr{"type":"log"}, "fileset":common.MapStr{"name":"auth", "module":"system"}, "prospector":common.MapStr{"type":"log"}, "beat":common.MapStr{"version":"6.3.1", "timezone":"-07:00", "name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "hostname":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc42006ac30), Source:"/var/log/auth.log", Offset:528591, Timestamp:time.Time{wall:0xbecef590600dcc76, ext:98263559, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x14c5, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-27T11:06:48.685-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbecef5ade8c6d6b9, ext:118244607969, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"beat":common.MapStr{"version":"6.3.1", "timezone":"-07:00", "name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "hostname":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "host":common.MapStr{"name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "source":"/var/log/auth.log", "offset":528591, "message":"Jul 27 11:06:37 mouli-i-038f2e3e573d951b6 sshd[3691]: Starting session: command for rdmon from 2600:1f18:2270:741e:3f2a:54ab:3f89:5fe9 port 49894 id 0", "input":common.MapStr{"type":"log"}, "fileset":common.MapStr{"module":"system", "name":"auth"}, "prospector":common.MapStr{"type":"log"}}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc42006ac30), Source:"/var/log/auth.log", Offset:528742, Timestamp:time.Time{wall:0xbecef590600dcc76, ext:98263559, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x14c5, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-27T11:06:49.458-0700	INFO	[monitoring]	log/log.go:124	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":440,"time":{"ms":8}},"total":{"ticks":3850,"time":{"ms":20},"value":3850},"user":{"ticks":3410,"time":{"ms":12}}},"info":{"ephemeral_id":"a7a58680-f4b8-4332-adfd-f101bdf33780","uptime":{"ms":120010}},"memstats":{"gc_next":7615056,"memory_alloc":4144944,"memory_total":421250472}},"filebeat":{"events":{"added":10,"done":10},"harvester":{"open_files":13,"running":13}},"libbeat":{"config":{"module":{"running":1}},"output":{"events":{"acked":4,"batches":7,"dropped":6,"total":10},"read":{"bytes":2296},"write":{"bytes":7283}},"pipeline":{"clients":5,"events":{"active":0,"published":10,"total":10},"queue":{"acked":10}}},"registrar":{"states":{"current":12,"update":10},"writes":{"success":7,"total":7}},"system":{"load":{"1":0.02,"15":0,"5":0.02,"norm":{"1":0.02,"15":0,"5":0.02}}}}}}
2018-07-27T11:06:53.685-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbecef5ade8c6e334, ext:118244611160, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"source":"/var/log/auth.log", "offset":528742, "message":"Jul 27 11:06:37 mouli-i-038f2e3e573d951b6 sshd[3691]: Close session: user rdmon from 2600:1f18:2270:741e:3f2a:54ab:3f89:5fe9 port 49894 id 0", "input":common.MapStr{"type":"log"}, "fileset":common.MapStr{"module":"system", "name":"auth"}, "prospector":common.MapStr{"type":"log"}, "beat":common.MapStr{"timezone":"-07:00", "version":"6.3.1", "name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "hostname":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "host":common.MapStr{"name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc42006ac30), Source:"/var/log/auth.log", Offset:528883, Timestamp:time.Time{wall:0xbecef590600dcc76, ext:98263559, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x14c5, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-27T11:07:03.686-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbecef5b1a8d78e96, ext:133245703613, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"host":common.MapStr{"name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "source":"/var/log/auth.log", "offset":528883, "message":"Jul 27 11:06:55 mouli-i-038f2e3e573d951b6 sshd[26661]: Connection from 2600:1f18:2270:741e:3f2a:54ab:3f89:5fe9 port 33916 on 2600:1f18:2270:741e:48e:c1e6:ffc0:c1e port 22", "fileset":common.MapStr{"name":"auth", "module":"system"}, "prospector":common.MapStr{"type":"log"}, "input":common.MapStr{"type":"log"}, "beat":common.MapStr{"name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "hostname":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "version":"6.3.1", "timezone":"-07:00"}}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc42006ac30), Source:"/var/log/auth.log", Offset:529054, Timestamp:time.Time{wall:0xbecef590600dcc76, ext:98263559, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x14c5, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-27T11:12:05.704-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbecef5fbe9e6a517, ext:430263469628, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"offset":532217, "message":"Jul 27 11:11:55 mouli-i-038f2e3e573d951b6 sshd[26808]: Connection closed by 2600:1f18:2270:741e:3f2a:54ab:3f89:5fe9 port 35524 [preauth]", "source":"/var/log/auth.log", "fileset":common.MapStr{"module":"system", "name":"auth"}, "prospector":common.MapStr{"type":"log"}, "input":common.MapStr{"type":"log"}, "beat":common.MapStr{"timezone":"-07:00", "name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "hostname":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "version":"6.3.1"}, "host":common.MapStr{"name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc42006ac30), Source:"/var/log/auth.log", Offset:532354, Timestamp:time.Time{wall:0xbecef590600dcc76, ext:98263559, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x14c5, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-27T11:12:15.708-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbecef5ffa9f8d8a6, ext:445264662475, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"host":common.MapStr{"name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "source":"/var/log/auth.log", "offset":532354, "message":"Jul 27 11:12:10 mouli-i-038f2e3e573d951b6 sshd[3691]: Starting session: command for rdmon from 2600:1f18:2270:741e:3f2a:54ab:3f89:5fe9 port 49894 id 0", "fileset":common.MapStr{"module":"system", "name":"auth"}, "prospector":common.MapStr{"type":"log"}, "input":common.MapStr{"type":"log"}, "beat":common.MapStr{"timezone":"-07:00", "name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "hostname":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "version":"6.3.1"}}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc42006ac30), Source:"/var/log/auth.log", Offset:532505, Timestamp:time.Time{wall:0xbecef590600dcc76, ext:98263559, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x14c5, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-27T11:12:15.708-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbecef5ffa9f8e54d, ext:445264665711, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"fileset":common.MapStr{"module":"system", "name":"auth"}, "beat":common.MapStr{"version":"6.3.1", "timezone":"-07:00", "name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "hostname":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "host":common.MapStr{"name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "source":"/var/log/auth.log", "offset":532505, "message":"Jul 27 11:12:10 mouli-i-038f2e3e573d951b6 sshd[3691]: Close session: user rdmon from 2600:1f18:2270:741e:3f2a:54ab:3f89:5fe9 port 49894 id 0", "prospector":common.MapStr{"type":"log"}, "input":common.MapStr{"type":"log"}}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc42006ac30), Source:"/var/log/auth.log", Offset:532646, Timestamp:time.Time{wall:0xbecef590600dcc76, ext:98263559, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x14c5, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-27T11:12:15.708-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbecef5ffa9f8eaef, ext:445264667150, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"offset":532646, "input":common.MapStr{"type":"log"}, "fileset":common.MapStr{"module":"system", "name":"auth"}, "prospector":common.MapStr{"type":"log"}, "beat":common.MapStr{"timezone":"-07:00", "hostname":"mouli-i-038f2e3e573d951b6.k.dev.eng-us", "version":"6.3.1", "name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "host":common.MapStr{"name":"mouli-i-038f2e3e573d951b6.k.dev.eng-us"}, "message":"Jul 27 11:12:12 mouli-i-038f2e3e573d951b6 sshd[3691]: Starting session: command for rdmon from 2600:1f18:2270:741e:3f2a:54ab:3f89:5fe9 port 49894 id 0", "source":"/var/log/auth.log"}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc42006ac30), Source:"/var/log/auth.log", Offset:532797, Timestamp:time.Time{wall:0xbecef590600dcc76, ext:98263559, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x14c5, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-27T11:12:19.460-0700	INFO	[monitoring]	log/log.go:124	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":460,"time":{"ms":8}},"total":{"ticks":3990,"time":{"ms":16},"value":3990},"user":{"ticks":3530,"time":{"ms":8}}},"info":{"ephemeral_id":"a7a58680-f4b8-4332-adfd-f101bdf33780","uptime":{"ms":450011}},"memstats":{"gc_next":6889456,"memory_alloc":4402624,"memory_total":434379744,"rss":-11476992}},"filebeat":{"events":{"added":8,"done":8},"harvester":{"open_files":3,"running":3}},"libbeat":{"config":{"module":{"running":1}},"output":{"events":{"acked":2,"batches":5,"dropped":6,"total":8},"read":{"bytes":1634},"write":{"bytes":6026}},"pipeline":{"clients":5,"events":{"active":0,"published":8,"total":8},"queue":{"acked":8}}},"registrar":{"states":{"current":12,"update":8},"writes":{"success":5,"total":5}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}
I stopped the service on 50+ servers, just enabled 6.3.1 on a server.
  1. Stopped the service
  2. delete existing pipelinee
  3. started service
  4. Log
instance# systemctl stop filebeat.service
instance# curl -XDELETE "http://sherlock:9200/_ingest/pipeline/filebeat-*"
instance# systemctl restart filebeat.service
instance# tail -n10 /var/log/filebeat/filebeat
2018-07-27T11:22:38.774-0700	INFO	log/harvester.go:228	Harvester started for file: /var/log/auth.log
2018-07-27T11:22:38.778-0700	INFO	log/input.go:113	Configured paths: [/var/log/auth.log* /var/log/secure*]
2018-07-27T11:22:38.787-0700	INFO	log/input.go:113	Configured paths: [/var/log/messages* /var/log/syslog*]
2018-07-27T11:22:38.787-0700	INFO	crawler/crawler.go:82	Loading and starting Inputs completed. Enabled inputs: 1
2018-07-27T11:22:38.787-0700	INFO	cfgfile/reload.go:122	Config reloader started
2018-07-27T11:22:38.789-0700	ERROR	fileset/factory.go:72	Error creating input: Can only start an input when all related states are finished: {Id:0-5317-51713 Finished:false Fileinfo:0xc420498680 Source:/var/log/auth.log Offset:538015 Timestamp:2018-07-27 11:22:38.787001557 -0700 PDT m=+0.048636661 TTL:-1ns Type:log Meta:map[] FileStateOS:5317-51713}
2018-07-27T11:22:38.789-0700	ERROR	cfgfile/reload.go:201	Unable to create runner due to error: Can only start an input when all related states are finished: {Id:0-5317-51713 Finished:false Fileinfo:0xc420498680 Source:/var/log/auth.log Offset:538015 Timestamp:2018-07-27 11:22:38.787001557 -0700 PDT m=+0.048636661 TTL:-1ns Type:log Meta:map[] FileStateOS:5317-51713}
2018-07-27T11:22:38.789-0700	INFO	cfgfile/reload.go:214	Loading of config files completed.
2018-07-27T11:22:39.779-0700	INFO	elasticsearch/client.go:690	Connected to Elasticsearch version 6.2.4
2018-07-27T11:22:39.780-0700	INFO	template/load.go:73	Template already exists and will not be overwritten.
Indeed, i just uninstalled the package on all 50 instances, now filebeat is running on only one instance.
current log: just wanted to share this log.
|2018-07-27T12:54:08.755-0700|INFO|[monitoring]|log/log.go:124|Non-zero metrics in the last 30s|{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":160},"total":{"ticks":780,"time":{"ms":8},"value":780},"user":{"ticks":620,"time":{"ms":8}}},"info":{"ephemeral_id":"4a992943-2964-4f31-8391-807246f6cc41","uptime":{"ms":5490010}},"memstats":{"gc_next":4194304,"memory_alloc":1864848,"memory_total":89560816}},"filebeat":{"events":{"added":2,"done":2},"harvester":{"open_files":1,"running":1}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":2,"batches":1,"total":2},"read":{"bytes":346},"write":{"bytes":1281}},"pipeline":{"clients":4,"events":{"active":0,"published":2,"total":2},"queue":{"acked":2}}},"registrar":{"states":{"current":12,"update":2},"writes":{"success":1,"total":1}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}|
|2018-07-27T12:54:38.755-0700|INFO|[monitoring]|log/log.go:124|Non-zero metrics in the last 30s|{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":160},"total":{"ticks":790,"value":790},"user":{"ticks":630}},"info":{"ephemeral_id":"4a992943-2964-4f31-8391-807246f6cc41","uptime":{"ms":5520009}},"memstats":{"gc_next":4194304,"memory_alloc":2030312,"memory_total":89726280}},"filebeat":{"harvester":{"open_files":1,"running":1}},"libbeat":{"config":{"module":{"running":0}},"pipeline":{"clients":4,"events":{"active":0}}},"registrar":{"states":{"current":12}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}|
|2018-07-27T12:55:08.755-0700|INFO|[monitoring]|log/log.go:124|Non-zero metrics in the last 30s|{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":160},"total":{"ticks":790,"time":{"ms":4},"value":790},"user":{"ticks":630,"time":{"ms":4}}},"info":{"ephemeral_id":"4a992943-2964-4f31-8391-807246f6cc41","uptime":{"ms":5550009}},"memstats":{"gc_next":4194304,"memory_alloc":2520960,"memory_total":90216928}},"filebeat":{"events":{"added":6,"done":6},"harvester":{"open_files":1,"running":1}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":6,"batches":1,"total":6},"read":{"bytes":377},"write":{"bytes":3323}},"pipeline":{"clients":4,"events":{"active":0,"published":6,"total":6},"queue":{"acked":6}}},"registrar":{"states":{"current":12,"update":6},"writes":{"success":1,"total":1}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}|
|2018-07-27T12:55:38.755-0700|INFO|[monitoring]|log/log.go:124|Non-zero metrics in the last 30s|{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":160},"total":{"ticks":800,"time":{"ms":4},"value":800},"user":{"ticks":640,"time":{"ms":4}}},"info":{"ephemeral_id":"4a992943-2964-4f31-8391-807246f6cc41","uptime":{"ms":5580010}},"memstats":{"gc_next":4194304,"memory_alloc":2771128,"memory_total":90467096}},"filebeat":{"harvester":{"open_files":1,"running":1}},"libbeat":{"config":{"module":{"running":0}},"pipeline":{"clients":4,"events":{"active":0}}},"registrar":{"states":{"current":12}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}|
|2018-07-27T12:56:08.755-0700|INFO|[monitoring]|log/log.go:124|Non-zero metrics in the last 30s|{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":160},"total":{"ticks":800,"time":{"ms":8},"value":800},"user":{"ticks":640,"time":{"ms":8}}},"info":{"ephemeral_id":"4a992943-2964-4f31-8391-807246f6cc41","uptime":{"ms":5610010}},"memstats":{"gc_next":4194304,"memory_alloc":1519096,"memory_total":91188640}},"filebeat":{"events":{"added":4,"done":4},"harvester":{"open_files":1,"running":1}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":4,"batches":2,"total":4},"read":{"bytes":690},"write":{"bytes":2562}},"pipeline":{"clients":4,"events":{"active":0,"published":4,"total":4},"queue":{"acked":4}}},"registrar":{"states":{"current":12,"update":4},"writes":{"success":2,"total":2}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}|
|2018-07-27T12:56:38.755-0700|INFO|[monitoring]|log/log.go:124|Non-zero metrics in the last 30s|{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":160},"total":{"ticks":810,"time":{"ms":4},"value":810},"user":{"ticks":650,"time":{"ms":4}}},"info":{"ephemeral_id":"4a992943-2964-4f31-8391-807246f6cc41","uptime":{"ms":5640010}},"memstats":{"gc_next":4194304,"memory_alloc":2275752,"memory_total":91945296}},"filebeat":{"events":{"added":4,"done":4},"harvester":{"open_files":1,"running":1}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":4,"batches":2,"total":4},"read":{"bytes":693},"write":{"bytes":2562}},"pipeline":{"clients":4,"events":{"active":0,"published":4,"total":4},"queue":{"acked":4}}},"registrar":{"states":{"current":12,"update":4},"writes":{"success":2,"total":2}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}|
|2018-07-27T12:57:08.755-0700|INFO|[monitoring]|log/log.go:124|Non-zero metrics in the last 30s|{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":160},"total":{"ticks":810,"time":{"ms":4},"value":810},"user":{"ticks":650,"time":{"ms":4}}},"info":{"ephemeral_id":"4a992943-2964-4f31-8391-807246f6cc41","uptime":{"ms":5670009}},"memstats":{"gc_next":4194304,"memory_alloc":3004864,"memory_total":92674408}},"filebeat":{"events":{"added":4,"done":4},"harvester":{"open_files":1,"running":1}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":4,"batches":2,"total":4},"read":{"bytes":687},"write":{"bytes":2578}},"pipeline":{"clients":4,"events":{"active":0,"published":4,"total":4},"queue":{"acked":4}}},"registrar":{"states":{"current":12,"update":4},"writes":{"success":2,"total":2}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}|
|2018-07-27T12:57:38.755-0700|INFO|[monitoring]|log/log.go:124|Non-zero metrics in the last 30s|{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":160},"total":{"ticks":820,"time":{"ms":4},"value":820},"user":{"ticks":660,"time":{"ms":4}}},"info":{"ephemeral_id":"4a992943-2964-4f31-8391-807246f6cc41","uptime":{"ms":5700009}},"memstats":{"gc_next":4194304,"memory_alloc":3495544,"memory_total":93165088}},"filebeat":{"events":{"added":4,"done":4},"harvester":{"open_files":1,"running":1}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":4,"batches":1,"total":4},"read":{"bytes":360},"write":{"bytes":2367}},"pipeline":{"clients":4,"events":{"active":0,"published":4,"total":4},"queue":{"acked":4}}},"registrar":{"states":{"current":12,"update":4},"writes":{"success":1,"total":1}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}|
