Here is the log:
2018-07-25T09:15:38.932-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbece466a77105996, ext:747401007978008, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"message":"Jul 25 09:15:36 autofind-i-0250f2df10123c4a3 sshd[25035]: User child is on pid 25085", "prospector":common.MapStr{"type":"log"}, "input":common.MapStr{"type":"log"}, "fileset":common.MapStr{"module":"system", "name":"auth"}, "beat":common.MapStr{"timezone":"-07:00", "name":"autofind-i-0250f2df10123c4a3.k.dev.eng-us", "hostname":"autofind-i-0250f2df10123c4a3.k.dev.eng-us", "version":"6.3.1"}, "host":common.MapStr{"name":"autofind-i-0250f2df10123c4a3.k.dev.eng-us"}, "source":"/var/log/auth.log", "offset":95506}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc420a5cc30), Source:"/var/log/auth.log", Offset:95591, Timestamp:time.Time{wall:0xbece25dd388af459, ext:714068032790436, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x10db, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-25T09:19:26.942-0700	INFO	[monitoring]	log/log.go:124	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":53440,"time":{"ms":8}},"total":{"ticks":238730,"time":{"ms":8},"value":238730},"user":{"ticks":185290}},"info":{"ephemeral_id":"363fa537-770b-4948-8dae-afdf30a094a2","uptime":{"ms":747630020}},"memstats":{"gc_next":5694272,"memory_alloc":3940440,"memory_total":21587357176}},"filebeat":{"harvester":{"open_files":4,"running":4}},"libbeat":{"config":{"module":{"running":5}},"pipeline":{"clients":15,"events":{"active":0}}},"registrar":{"states":{"current":14}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}
2018-07-25T09:19:56.942-0700	INFO	[monitoring]	log/log.go:124	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":53440,"time":{"ms":4}},"total":{"ticks":238730,"time":{"ms":4},"value":238730},"user":{"ticks":185290}},"info":{"ephemeral_id":"363fa537-770b-4948-8dae-afdf30a094a2","uptime":{"ms":747660020}},"memstats":{"gc_next":5694272,"memory_alloc":4350864,"memory_total":21587767600}},"filebeat":{"harvester":{"open_files":4,"running":4}},"libbeat":{"config":{"module":{"running":5}},"pipeline":{"clients":15,"events":{"active":0}}},"registrar":{"states":{"current":14}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}
2018-07-25T09:20:08.934-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbece46adf79e7df0, ext:747671017293480, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"message":"Jul 25 09:20:01 autofind-i-0250f2df10123c4a3 CRON[25161]: pam_unix(cron:session): session opened for user root by (uid=0)", "input":common.MapStr{"type":"log"}, "fileset":common.MapStr{"module":"system", "name":"auth"}, "prospector":common.MapStr{"type":"log"}, "beat":common.MapStr{"timezone":"-07:00", "version":"6.3.1", "name":"autofind-i-0250f2df10123c4a3.k.dev.eng-us", "hostname":"autofind-i-0250f2df10123c4a3.k.dev.eng-us"}, "host":common.MapStr{"name":"autofind-i-0250f2df10123c4a3.k.dev.eng-us"}, "source":"/var/log/auth.log", "offset":95972}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc420a5cc30), Source:"/var/log/auth.log", Offset:96094, Timestamp:time.Time{wall:0xbece25dd388af459, ext:714068032790436, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x10db, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-25T09:20:13.934-0700	WARN	elasticsearch/client.go:502	Cannot index event publisher.Event{Content:beat.Event{Timestamp:time.Time{wall:0xbece46adf79e8d0c, ext:747671017297335, loc:(*time.Location)(0x1f4a300)}, Meta:common.MapStr{"pipeline":"filebeat-6.3.1-system-auth-pipeline"}, Fields:common.MapStr{"input":common.MapStr{"type":"log"}, "fileset":common.MapStr{"name":"auth", "module":"system"}, "prospector":common.MapStr{"type":"log"}, "beat":common.MapStr{"timezone":"-07:00", "name":"autofind-i-0250f2df10123c4a3.k.dev.eng-us", "hostname":"autofind-i-0250f2df10123c4a3.k.dev.eng-us", "version":"6.3.1"}, "host":common.MapStr{"name":"autofind-i-0250f2df10123c4a3.k.dev.eng-us"}, "source":"/var/log/auth.log", "offset":96094, "message":"Jul 25 09:20:01 autofind-i-0250f2df10123c4a3 CRON[25161]: pam_unix(cron:session): session closed for user root"}, Private:file.State{Id:"", Finished:false, Fileinfo:(*os.fileStat)(0xc420a5cc30), Source:"/var/log/auth.log", Offset:96205, Timestamp:time.Time{wall:0xbece25dd388af459, ext:714068032790436, loc:(*time.Location)(0x1f4a300)}, TTL:-1, Type:"log", Meta:map[string]string{}, FileStateOS:file.StateOS{Inode:0x10db, Device:0xca01}}}, Flags:0x1} (status=400): {"type":"illegal_argument_exception","reason":"pipeline with id [filebeat-6.3.1-system-auth-pipeline] does not exist"}
2018-07-25T09:20:26.942-0700	INFO	[monitoring]	log/log.go:124	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":53440,"time":{"ms":8}},"total":{"ticks":238740,"time":{"ms":16},"value":238740},"user":{"ticks":185300,"time":{"ms":8}}},"info":{"ephemeral_id":"363fa537-770b-4948-8dae-afdf30a094a2","uptime":{"ms":747690019}},"memstats":{"gc_next":5695840,"memory_alloc":3572904,"memory_total":21588652112}},"filebeat":{"events":{"added":5,"done":5},"harvester":{"open_files":4,"running":4}},"libbeat":{"config":{"module":{"running":5}},"output":{"events":{"acked":3,"batches":2,"dropped":2,"total":5},"read":{"bytes":763},"write":{"bytes":3473}},"pipeline":{"clients":15,"events":{"active":0,"published":5,"total":5},"queue":{"acked":5}}},"registrar":{"states":{"current":14,"update":5},"writes":{"success":2,"total":2}},"system":{"load":{"1":0,"15":0,"5":0,"norm":{"1":0,"15":0,"5":0}}}}}}
