I have answered in the other thread. You seem to be on the good path, you just need to install Auditbeat on more servers. Please let us know if you require more information.
I have installed but it doesn't work
@tudor Could you give the step by step instruction ?
If it works getting the data from the system where ES is working, but not from other servers, I suspect the Output configuration in Auditbeat is not correct. Could you post your auditbeat.yml and the logs?
How did you install Auditbeat? From DEB/RPM? Depending on the installation method, the logs location will be different. It should be either in /var/log/auditbeat or in logs/auditbeat in the install directory.
###################### Auditbeat Configuration Example #########################
# This is an example configuration file highlighting only the most common
# options. The auditbeat.reference.yml file from the same directory contains all
# the supported options with more comments. You can use it as a reference.
# You can find the full configuration reference here:
# https://www.elastic.co/guide/en/beats/auditbeat/index.html
#========================== Modules configuration =============================
auditbeat.modules:
- module: auditd
# Load audit rules from separate files. Same format as audit.rules(7).
audit_rule_files: [ '${path.config}/audit.rules.d/*.conf' ]
audit_rules: |
## Define audit rules here.
## Create file watches (-w) or syscall audits (-a or -A). Uncomment these
## examples or add your own rules.
## If you are on a 64 bit platform, everything should be running
## in 64 bit mode. This rule will detect any use of the 32 bit syscalls
## because this might be a sign of someone exploiting a hole in the 32
## bit API.
#-a always,exit -F arch=b32 -S all -F key=32bit-abi
## Executions.
#-a always,exit -F arch=b64 -S execve,execveat -k exec
## External access (warning: these can be expensive to audit).
#-a always,exit -F arch=b64 -S accept,bind,connect -F key=external-access
## Identity changes.
#-w /etc/group -p wa -k identity
#-w /etc/passwd -p wa -k identity
#-w /etc/gshadow -p wa -k identity
## Unauthorized access attempts.
#-a always,exit -F arch=b64 -S open,creat,truncate,ftruncate,openat,open_by_handle_at -F exit=-EACCES -k access
#-a always,exit -F arch=b64 -S open,creat,truncate,ftruncate,openat,open_by_handle_at -F exit=-EPERM -k access
- module: file_integrity
paths:
- /bin
- /usr/bin
- /sbin
- /usr/sbin
- /etc
- module: system
datasets:
- host # General host information, e.g. uptime, IPs
- login # User logins, logouts, and system boots.
- package # Installed, updated, and removed packages
- process # Started and stopped processes
- socket # Opened and closed sockets
- user # User information
# How often datasets send state updates with the
# current state of the system (e.g. all currently
# running processes, all open sockets).
state.period: 1m
# Enabled by default. Auditbeat will read password fields in
# /etc/passwd and /etc/shadow and store a hash locally to
# detect any changes.
user.detect_password_changes: true
# File patterns of the login record files.
login.wtmp_file_pattern: /var/log/wtmp*
login.btmp_file_pattern: /var/log/btmp*
#==================== Elasticsearch template setting ==========================
setup.template.settings:
index.number_of_shards: 1
#index.codec: best_compression
#_source.enabled: false
#================================ General =====================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name:
# The tags of the shipper are included in their own field with each
# transaction published.
# Optional fields that you can specify to add additional information to the
# output.
#fields:
# env: staging
#============================== Dashboards =====================================
# These settings control loading the sample dashboards to the Kibana index. Loading
# the dashboards is disabled by default and can be enabled either by setting the
# options here or by using the `setup` command.
#setup.dashboards.enabled: false
# The URL from where to download the dashboards archive. By default this URL
# has a value which is computed based on the Beat name and version. For released
# versions, this URL points to the dashboard archive on the artifacts.elastic.co
# website.
#setup.dashboards.url:
#============================== Kibana =====================================
# Starting with Beats version 6.0.0, the dashboards are loaded via the Kibana API.
# This requires a Kibana endpoint configuration.
setup.kibana:
# Kibana Host
# Scheme and port can be left out and will be set to the default (http and 5601)
# In case you specify and additional path, the scheme is required: http://localhost:5601/path
# IPv6 addresses should always be defined as: https://[2001:db8::1]:5601
host: "https://172.16.5.199:5601"
# Kibana Space ID
# ID of the Kibana Space into which the dashboards should be loaded. By default,
# the Default Space will be used.
#space.id:
# Browser from/to Kibana
setup.kibana.ssl.enabled: true
setup.kibana.ssl.certificate: "/etc/kibana/certs/kibana.crt"
setup.kibana.ssl.certificate_authorities: ["/etc/kibana/certs/ca/ca.crt"]
setup.kibana.ssl.key: "/etc/kibana/certs/kibana.key"
#xpack.security.enabled: true
#elasticsearch.username: "elastic"
#elasticsearch.password: "nOFtPk9Wwd1mqPnAEoYC"
#============================= Elastic Cloud ==================================
# These settings simplify using Auditbeat with the Elastic Cloud (https://cloud.elastic.co/).
# The cloud.id setting overwrites the `output.elasticsearch.hosts` and
# `setup.kibana.host` options.
# You can find the `cloud.id` in the Elastic Cloud web UI.
#cloud.id:
# The cloud.auth setting overwrites the `output.elasticsearch.username` and
# `output.elasticsearch.password` settings. The format is `<user>:<pass>`.
#cloud.auth:
#================================ Outputs =====================================
output.elasticsearch:
#hosts: ["172.16.5.199:9200"]
# Optional protocol and basic auth credentials.
#protocol: "https"
#username: "elastic"
#password: "<redacted>"
#ssl.verification_mode: none
output.elasticsearch.hosts: ['https://172.16.5.199:9200']
#output.elasticsearch.hosts: ['http://localhost:9200']
output.elasticsearch.hosts: ['172.16.5.199:9200']
output.elasticsearch.protocol: https
output.elasticsearch.ssl.certificate: "/etc/filebeat/certs/wazuh-manager.crt"
output.elasticsearch.ssl.key: "/etc/filebeat/certs/wazuh-manager.key"
output.elasticsearch.ssl.certificate_authorities: ["/etc/filebeat/certs/ca/ca.crt"]
output.elasticsearch.username: "elastic"
output.elasticsearch.password: "<redacted>"
#----------------------------- Logstash output --------------------------------
#output.logstash:
# The Logstash hosts
#hosts: ["localhost:5044"]
# Optional SSL. By default is off.
# Client Certificate Key
#================================ Processors =====================================
# Configure processors to enhance or manipulate events generated by the beat.
processors:
- add_host_metadata: ~
- add_cloud_metadata: ~
#================================ Logging =====================================
# Sets log level. The default log level is info.
# Available log levels are: error, warning, info, debug
#logging.level: debug
# At debug level, you can selectively enable logging only for some components.
# To enable all selectors use ["*"]. Examples of other selectors are "beat",
# "publish", "service".
#logging.selectors: ["*"]
#============================== Xpack Monitoring ===============================
# auditbeat can export internal metrics to a central Elasticsearch monitoring
# cluster. This requires xpack monitoring to be enabled in Elasticsearch. The
# reporting is disabled by default.
# Set to true to enable the monitoring reporter.
#monitoring.enabled: false
# Sets the UUID of the Elasticsearch cluster under which monitoring data for this
# Auditbeat instance will appear in the Stack Monitoring UI. If output.elasticsearch
# is enabled, the UUID is derived from the Elasticsearch cluster referenced by output.elasticsearch.
#monitoring.cluster_uuid:
# Uncomment to send the metrics to Elasticsearch. Most settings from the
# Elasticsearch output are accepted here as well.
# Note that the settings should point to your Elasticsearch *monitoring* cluster.
# Any setting that is not set is automatically inherited from the Elasticsearch
# output configuration, so if you have the Elasticsearch output configured such
# that it is pointing to your Elasticsearch monitoring cluster, you can simply
# uncomment the following line.
#monitoring.elasticsearch:
#================================= Migration ==================================
# This allows to enable 6.7 migration aliases
#migration.6_to_7.enabled: true
@tudor How to upload file into this forum?
Auditbeat on Clients side:
auditbeat.modules:
- module: auditd
audit_rules: |
## bit API.
## Executions.
paths:
- /bin
- /usr/bin
- /sbin
- /usr/sbin
- /etc
- module: system
datasets:
state.period: 1m
#name:
# output.
#fields:
# env: staging
# website.
setup.kibana:
# Kibana Host
host: "172.16.5.199:5601"
# Kibana Space ID
#space.id:
#cloud.id:
#cloud.auth:
#protocol: "https"
#output.elasticsearch.hosts: ['https://172.16.5.199:9200']
#output.elasticsearch.hosts: ['172.16.5.199:9200']
#output.elasticsearch.ssl.certificate: "/etc/filebeat/certs/wazuh-manager.crt"
#output.elasticsearch.ssl.key: "/etc/filebeat/certs/wazuh-manager.key"
#output.elasticsearch.ssl.certificate_authorities: ["/etc/filebeat/certs/ca/ca.crt"]
#output.elasticsearch.username: "elastic"
#output.elasticsearch.password: "<redacted>"
#output.logstash:
#hosts: ["172.16.5.199:5044"]
Clients side (Con't):
processors:
@tudor My server is running CentOS 7 and the client is Ubuntu 18.04.3
Thanks, can you switch Auditbeat to debug mode? Add or uncomment logging.level: debug on one of the servers where it doesn't work and then send us the logs again. I hope that will give us a better indication of what doesn't work.
uncomment logging.level: debug that line on server side or client side ?
On the Auditbeat instance that doesn't work. That's client side from what I understand, right?
You're right !
You have found an error on my configuration files both server and client ?
