Having problem in reverse mapping of hostname to ip address using DNS filter
I am trying to use the DNS filter to map the hostname to IPaddress , below is the sample configuration I tried to map google.com to ipaddress
filter{
    mutate {
    add_field => {"hostname", "google.com"}
   dns {
   reverse => ["hostname"]
   action => "replace"
   nameserver => ["8.8.8.8", "8.8.4,4"]
   timeout => 10.0 #Just to make sure timeout is not the problem here
the hostname does not translate to ip address , let me know what i am doing wrong here
You have it the wrong way around...
reverse takes an IP address and looks up its name.
resolve takes a name and looks up its IP address.
Thanks a lot
