Dear, how are you?
I'm using the community version of elasticstack, I'm trying to setup multiple pipelines using Docker. I need to set up a pipeline for jboss and another for the nginx logs.
Configuring Logstash on docker compose
I configured the pipelines.xml file
https://pastebin.com/GjnhZ5QE
The logstash.conf:
https://pastebin.com/sb9kU69a
The jboss filter file and nginx
03-jboss.conf:
https://pastebin.com/U96XMJsj
04-nginx-filter.conf
https://pastebin.com/tATDUsrz
The logstash goes up but upon accessing the kibana discovery it does not show the geo.ip options in the nginx logs.
Ja in the kibana console, when I access the tab monitoring and I go in logstsh it shows omente 1 pipelime, the main, even I pointing to the pipeline.xml file.
I tried several configurations, but nothing worked, can you help me?
