amruth
(Amruth)
November 13, 2017, 10:04pm
1
I am using following filter in Logstash,
if "INFO" in [message] and "instance" in [message] {
mutate{
remove_field => ["name"]
And it's doing nothing. I don't understand what the problem is.
Also, it is actually "instance:" , will I have to provide the exact string instead of "instance"? (I am not including : )
Whether your configuration works depends on what the events look like, right?
No, the in operator performs a substring search. It's not an equality comparison.
amruth
(Amruth)
November 14, 2017, 2:43pm
3
Here is the sample input,
2017-11-13 21:30:48:483195 [139718491015040 rid: ] INFO [] Server: listens on port 9111
2017-11-13 21:30:48:4858 [139718119044864 rid: ] INFO instance: started client connection thread, address of client: xx.xx.xx, port: 11111
2017-11-13 21:30:48:48605 [139718119044864 rid: ] INFO [] Server: started client connection thread, address of client: xx.xx.xx, port: 11111
2017-11-13 21:30:48:98756 [139718119044864 rid: ] INFO instance: started client connection thread, address of client: xx.xx.xx, port: 11111
2017-11-13 21:30:49:48606 [139718119044864 rid: ] INFO [] [Query Timestamp: 1510626648963169] Server: received query: address of client: xx.xx.xx, port: 11111
Here is the config,
Input{
file{
path=>"/opt/server.log"
start_position=> "beginning"
sincedb_path => "/opt/failure_sincedb.log"
type=>"failure"
codec => multiline {
pattern => "^%{TIMESTAMP_ISO8601}"
negate => true
what => previous
auto_flush_interval => 10
max_lines => 100000
max_bytes => "1000 MiB"
filter{
if "INFO" in [message] and "instance:" in [message]{
grok {
match => {"message" => "%{TIMESTAMP_ISO8601:timestamp}%{GREEDYDATA}INFO\s%{GREEDYDATA:error}"}
mutate{
remove_field => ["message"]
add_field =>{"component" => "Queries"}
date {
match => ["timestamp", "ISO8601"]
target => "time"
mutate{
remove_field => ["timestamp"]
output{
file{
path => "/tmp/logstash/server10.log"
None of those sample lines contain "instance:".
amruth
(Amruth)
November 14, 2017, 2:47pm
5
Sorry, edited the post can you please check once again? 2nd and 4th lines
Okay, so far so good. Please show an event that has been processed by Logstash. Use a stdout { codec => rubydebug } output.
amruth
(Amruth)
November 14, 2017, 3:09pm
8
I am getting _dateparsefailure,
"path" => "path/test.log",
"component" => "Queries",
"@timestamp" => 2017-11-14T15:04:29.322Z,
"@version" => "1",
"host" => "xxx",
"type" => "failure",
"error" => "instance: started client connection thread, address of clie
nt: xx.xx.xx, port: 11111\r",
"tags" => [
[0] "_dateparsefailure"
Okay, but then your conditional clearly works. Since you're deleting the timestamp field I can't tell what you're asking the date filter to parse.
amruth
(Amruth)
November 14, 2017, 3:37pm
10
I am deleting timestamp field after applying date filter. It shouldn't have any effect, right?
Also I have updated,
match => ["timestamp", "yyyy-MM-dd HH:mm:ss:SSSSSS"]
It's working without any issue. ISO8601 is the culprit here?
Well, it severely affects my ability to debug your problem when you're destroying the evidence.
Seems so.
amruth
(Amruth)
November 14, 2017, 4:06pm
12
Here is the output with timestamp field(using match => ["timestamp", "yyyy-MM-dd HH:mm:ss:SSSSSS"] ),
"@timestamp" => 2017-11-14T16:04:00.621Z,
"@version" => "1",
"host" => "xxxx",
"time" => 2017-11-14T02:30:48.980Z,
"timestamp" => "2017-11-13 21:30:48:98"
Perhaps you need SS instead of SSSSSS in the date pattern. To deal with microseconds with varying number of digits you might have to use multiple date patterns. You could also truncate the last the timestamp to only include milliseconds since that's the precision ES can store anyway.
amruth
(Amruth)
November 14, 2017, 7:47pm
14
The config what I gave to you is a part of config file. I have 4 different conditions in the filter and for one of the conditions I have 3 other conditions to be checked. (instance: falls under this condition). I am sending th logs over http to another logstash instance.
Will too many filter on Logstash result in loosing data?
