How to access third party rest api using http_poller,http filter and ruby filter using basic authentication,header and body
logstash version : 6.3.1
curl -k -v -i -u 'API Key for V3':'API Secret for V3' 'https://api.com/v3/token' -d 'grant_type=password&username=&password=< Password>&scope=< Area UUID>'
Using above curl command I am able to connect to server.
I need to transform curl command to logstash http_poller plugin format.After doing the changes, I couldn't establish the connection.
Could you pleease let me where I am doing mistake.
Do I sent request body data in add_field ??? If not how to sent request body data in http_poller plugin during the request
http_poller {
urls => {
test => {
url => "https://api.com/v3/token"
method => post
headers => {
Accept => "application/json"
Content-Type=>"application/x-www-form-urlencoded"
Authorization => "Basic Oh4NXRilNGcWNidHdONjk="
user => "username"
password => "password"
	# Adding request body data in add_field, is this correct
	add_field =>{
	  "grant_type"=> "password"
	  "username'=> 'username"
	  "password'=> 'password"
	  "scope'=> '5caf04b4"
request_timeout => 60
schedule => { cron => "* * * * * UTC"}
codec => "json"
metadata_target => "http_poller_metadata"
same way i tried with http filter, but no luck .
I need to transform curl command to logstash http filter plugin format.After doing the changes, I couldn't establish the connection.
http {
url =>"https://api.com/v3/token"
 verb =>"POST"
 user =>"username"
 headers => {
       "Content-Type"=>"application/x-www-form-urlencoded"
	   "Accept" => "application/json"
 #body_format => "json"
 body => {
          grant_type => "password"
          username => "username"
          scope => "5caf04b4"
 target_body => "response_message"
Error showing , response_type or grant_type required when i am executing it in logstash http filter.
same way I tried with ruby filter, but no luck.
ruby{
code => "
require 'net/http'
require 'uri'
require 'json'
uri = URI('https://api.com/v3/token')
header = {'Content-Type'=>'application/x-www-form-urlencoded','Accept'=> 'application/json'}
request = Net::HTTP::Post.new(uri,header)
request.basic_auth '9xx5tyyyyy', 'xxxxxxxxxx69'
request.set_form_data({
				   'grant_type'=> 'password',
				   'username'=> 'username',
				   'password'=> 'passwordof user',
				   'scope'=> '5caf04b4'}
response = Net::HTTP.start(uri.hostname, uri.port, use_ssl: uri.scheme == 'https') do |http|
http.request(request)
end
event.set('response',response.body)
Error showing :[ERROR][logstash.filters.ruby] Ruby exception occurred: An existing connection was forcibly closed by the remote host
What's the problem with using
body => "grant_type=password&username=&password=< Password>&scope=< Area UUID>" body_format => "text"
as I suggested in the other thread about this?
Thank you for prompt response. I used the request body as you mentioned, but its not working.
Logstash is showing error grant_type is required, in the request body I am sending grant_type along with url request
[ERROR][logstash.filters.http ] error during HTTP request {:url=>"https://api.com/v3/token", :code=>400, :response=>"{"error":"invalid_request",
"error_description":"response_type or grant_type is required"}"}
"@version" => "1",
"@timestamp" => 2019-10-03T02:42:26.748Z,
"tags" => [
[0] "_httprequestfailure"
"host" => "Z507B-9D3F-00E3",
"message" => "kk\r"
I am able to access third party rest API using logstash http_poller input plugin.
**# Do the base 64 encode of username and password (username:password) **
# Use the encoded value of (username:password) in authorization field.
option 1:-
http_poller {
urls => {
test_url =>{
url => "https://apicom/v3/token"
method => post
headers => {
"Content-Type" => "application/x-www-form-urlencoded"
# assign encoded value of username:password into authorization field.
"Authorization" => "Basic username:password"
params =>{
"username"=> "${myusername}"
"password"=>"${mypassword}"
  	"grant_type"=>"password"
  	"scope"=>"${scope}"
codec => "json"
# request timeout (in seconds) for the entire request.
# Current configured time for this scheduler, here every 1 min, scheduler will triger the request.
schedule => { cron => "*/1 * * * * UTC"}
option 2:-
http_poller {
urls => {
test_url =>{
method => post
user => "${api_key}"
password => "${api_secret}"
headers => {
> params =>{
  	username => "${myusername}"
  	password => "${mypassword}"
                   grant_type=>"password"
                    scope=>"${scope}"
codec => "json"
#timeout (in seconds) for the entire request.
#metadata_target => "http_poller_metadata"
stdout {
codec => rubydebug
