Just wondering why you try to send a mapping to ES ?
BTW, your mapping is incorrect. You don’t have to define each attachment.
In the README file, I wrote:
$ curl -X PUT http://127.0.0.1:9200/my_db/my_db/_mapping -d '{
"my_db": {
"properties": {
  "_attachments": {
    "properties": {
      "attachment": {
        "type": "attachment"
  "yourfield" : {
    "type": "string"
I suggest that you try to simply get attachments from couchDb with the example I wrote and then, if working and if you really need to, play with mappings.
Try also to make simplier searches to start. Something like:
curl -XGET 'http://localhost:9200/my_test_couchdb_attachments/my_test_couchdb_attachments/_search' -d '{"query" : {"text" : { "_all" : "temperature" } }
(note the lowercase t on temperature).
Documentation is here : https://github.com/dadoonet/elasticsearch-river-couchdb/tree/attachments https://github.com/dadoonet/elasticsearch-river-couchdb/tree/attachments
HTH
David.
De : elasticsearch@googlegroups.com [mailto:elasticsearch@googlegroups.com] De la part de Chi Dung Tran
Envoyé : dimanche 8 janvier 2012 02:16
À : "elasticsearch@googlegroups.com"
Objet : Re : how to create index for a attachment of a doc in couchDB with ES?
Hi
But it doesn'e work for me.
I receive the same results as the mail I have already sent (below)
Please explain it to me.
You can see, I donot have hits.
Did I make a mistake or not?
----- Mail transféré -----
De : Chi Dung Tran dungtctin4@yahoo.com
À : "elasticsearch@googlegroups.com" elasticsearch@googlegroups.com
Envoyé le : Jeudi 29 Décembre 2011 16h42
Hello
I have tested it but it doesnot work well.
I attach 4 files to the 2 couchdb documents like that:
"_id": "Doc1",
"_rev": "5-4d607b7d88985097462ae9b2f67bc5ac",
"message": "Elastic Search",
"_attachments": {
"exam.docx": {
"content_type": "application/vnd.openxmlformats-officedocument.wordprocessingml.document",
"revpos": 4,
"digest": "md5-ecdBcsbc6w7mC1EOgd5SIg==",
"length": 10007,
"stub": true
"2230681.pdf": {
"content_type": "application/pdf",
"revpos": 2,
"digest": "md5-BUhqhHiVqKybxrfGsQTixQ==",
"length": 956146,
"stub": true
"_id": "Doc2",
"_rev": "7-dd58025abc2002566b6f458ad3d83d4d",
"message": test attachments",
"_attachments": {
"TestAttachments.txt": {
"content_type": "text/plain",
"revpos": 6,
"digest": "md5-aLTD+adMRHPw2+WMIN/42Q==",
"length": 89,
"stub": true
"DynamicPublishingUseCases.doc": {
"content_type": "application/msword",
"revpos": 2,
"digest": "md5-FRdhydLr57C+q3ff6xLEmA==",
"length": 22528,
"stub": true
Here is my test with elastic search:
curl -X PUT "localhost:9200/test_idx_couchdb_attachments"
{"ok":true,"acknowledged":true}
curl -XPUT 'http://localhost:9200/_river/test_river_couchdb_attachments/_meta' -d '{"type" : "couchdb", "couchdb" : {"host" : "localhost","port" : 5984,"db" : "my_test_couchdb_attachments","filter" : null,"ignore_attachments":false}},"index" : {"index" : "test_idx_couchdb_attachments", "type" : "test_mapping_couchdb_attachments" } }'
{"ok":true,"_index":"_river","_type":"test_river_couchdb_attachments","_id":"_meta","_version":1}
At first, I type:
curl -X PUT http://127.0.0.1:9200/my_test_couchdb_attachments/my_test_couchdb_attachments/_mapping -d '{
"my_test_couchdb_attachments": {
"properties": {
"_attachments": {
"properties": {
"2230681.pdf": {
"type": "attachment", "index" : "analyzed"
"exam.docx": {
"message" : {
"type": "string", "index" : "analyzed"
and I receive results:
{"error":"MergeMappingException[Merge failed with failures {[Can't merge a non object mapping [TestAttachments.txt] with an object mapping [TestAttachments.txt], Can't merge a non object mapping [2230681.pdf] with an object mapping [2230681.pdf], Can't merge a non object mapping [exam.docx] with an object mapping [exam.docx], Can't merge a non object mapping [DynamicPublishingUseCases.doc] with an object mapping [DynamicPublishingUseCases.doc]]}]
So I change and I succeed:
"properties": {
"_attachments": {
"properties": {
""2230681.pdf"": {
""DynamicPublishingUseCases.doc"": {
""TestAttachments.txt"": {
""exam.docx"": {
"message" : {
curl -XPOST 'http://localhost:9200/my_test_couchdb_attachments/my_test_couchdb_attachments/_search?pretty=true' -d '{"query" : {"wildcard" : { "_all" : "*" } } }'
This query works well by returning two documents
these queries donot work well with errors or no expected results:curl -XGET 'http://localhost:9200/my_test_couchdb_attachments/my_test_couchdb_attachments/_search' -d '{"query" : {"text" : { "_attachments."2230681.pdf".content" : "Temperature" } } }'{"took":0,"timed_out":false,"_shards":{"total":5,"successful":5,"failed":0},"hits":{"total":0,"max_score":null,"hits":[]}}curl -XGET 'http://localhost:9200/my_test_couchdb_attachments/my_test_couchdb_attachments/_search' -d '{"query" : {"text" : { "_attachments.[2230681.pdf] : "Temperature" } } }'{"error":"SearchPhaseExecutionException[Failed to execute phase [query], total failure; shardFailures {[CHYAFYCERMGHlBvKHiEagA][my_test_couchdb_attachments][3]: SearchParseException[[my_test_couchdb_attachments][3]: from[-1],size[-1]: Parse Failure [Failed to parse source [{"query" : {"text" : { "_attachments.[2230681.pdf] : "Temperature" } } }]]]; nested: QueryParsingException[[my_test_couchdb_attachments] Failed to parse]; nested: JsonParseException[Unexpected character ('T' (code 84)): was expecting a colon to separate field name and value\n at [Source: [B@582a85; line: 1, column: 56]]; }]curl -XPOST 'http://localhost:9200/my_test_couchdb_attachments/my_test_couchdb_attachments/_search?pretty=true' -d '{"query" : {"text" : { "_attachments."DynamicPublishingUseCases.doc"" : "Rendering" } } }'{ "took" : 0, "timed_out" : false, "_shards" : { "total" : 5, "successful" : 5, "failed" : 0 }, "hits" : { "total" : 0, "max_score" : null, "hits" : [ ] }}curl -XPOST 'http://localhost:9200/my_test_couchdb_attachments/my_test_couchdb_attachments/_search?pretty=true' -d '{"query" : {"text_phrase" : { "_attachments."TestAttachments.txt"" : "Couchdb" } } }'{ "took" : 0, "timed_out" : false, "_shards" : { "total" : 5, "successful" : 5, "failed" : 0 }, "hits" : { "total" : 0, "max_score" : null, "hits" : [ ] }}I have used Elastic search 0.18.4 with river Couchdb 1.1.0 and mapper-attachments plugins 1.1.0Please explain to me and how to index couchdb attachments and make it searchable?Maybe I should submit the pdf files whose content is encoded with base64? All my files in my test arenot encoded.Thanks a lot
De : David Pilato david@pilato.fr
À : elasticsearch elasticsearch@googlegroups.com
Envoyé le : Mercredi 28 Décembre 2011 14h12
Objet : Re: how to create index for a attachment of a doc in couchDB with ES?
Did anyone test it ?BTW, I updated the README file :https://github.com/dadoonet/elasticsearch-river-couchdb/blob/attachments/README.mdPlease let me know (CouchDB river users) if there is any regression orif I can submit the pull request.Thanks,David.On 22 déc, 00:11, "David Pilato" da...@pilato.fr wrote:> Hi there,>> I just finished something to deal with couchDb attachments using elasticsearch-mapper-attachments.>> Before going further, is it possible for you to fork my code [1], compile it and launch the main test class CouchdbRiverBinaryAttachementTest and send some docs with one or more attachments and see if you can search for it ?>> I tried with a very simple PDF file and it seems to work fine.>> I start to write a little documentation about it [2] (see at the end).>> You can also download the plugin [3] and install it instead of the previous couchDb plugin.>> BTW, you should have installed before the elasticsearch-mapper-attachments plugin [4].>> Please let me know if it’s working or not for you.>> Cheers,>> David.>> [1]https://github.com/dadoonet/elasticsearch-river-couchdb/tree/attachments> [2]https://github.com/dadoonet/elasticsearch.github.com/blob/b77ebec4e44...> [3]https://github.com/downloads/dadoonet/elasticsearch-river-couchdb/ela...> [4]https://github.com/elasticsearch/elasticsearch-mapper-attachments
