I'm using Cloud Instance and all the version are the latest.
NOTE: This is a trail version hosted on AWS.
We are using external application -->Gerrit and we would like to know how to use the Elastic APM to monitor the application which is not built by us.
Can elastic run APM on applications which are not developed by the company and only hosted by us????
The documentation states the following but when i do it it simpley fails to start the application
https://prodtest.kb.europe-west3.gcp.cloud.es.io:9243/app/home#/tutorial/apm
[root@awsmblx108as602 bin]# java -javaagent:/tmp/elastic-apm-agent-1.26.0.jar \
> -Delastic.apm.service_name=gerrit \
> -Delastic.apm.server_urls=https://e8544a56748c4b109e421b4b5da78319.apm.europe-west3.gcp.cloud.es.io:443 \
> -Delastic.apm.secret_token=kN8ZVOd99TDcRMSWqm \
> -Delastic.apm.environment=production \
> -Delastic.apm.application_packages=org.example \
> -jar /data/gerrit/bin/gerrit.war
WARNING: sun.reflect.Reflection.getCallerClass is not supported. This will impact performance.
2021-10-07 12:43:37,633 [main] INFO co.elastic.apm.agent.util.JmxUtils - Found JVM-specific OperatingSystemMXBean interface: com.sun.management.OperatingSystemMXBean
2021-10-07 12:43:37,663 [main] INFO co.elastic.apm.agent.configuration.StartupInfo - Starting Elastic APM 1.26.0 as gerrit on Java 11.0.10 Runtime version: 11.0.10+8-LTS-162 VM version: 11.0.10+8-LTS-162 (Oracle Corporation) Linux 4.18.0-305.3.1.el8_4.x86_64
2021-10-07 12:43:37,663 [main] INFO co.elastic.apm.agent.configuration.StartupInfo - service_name: 'gerrit' (source: Java System Properties)
2021-10-07 12:43:37,663 [main] INFO co.elastic.apm.agent.configuration.StartupInfo - environment: 'production' (source: Java System Properties)
2021-10-07 12:43:37,664 [main] INFO co.elastic.apm.agent.configuration.StartupInfo - secret_token: 'XXXX' (source: Java System Properties)
2021-10-07 12:43:37,664 [main] INFO co.elastic.apm.agent.configuration.StartupInfo - server_urls: 'https://e8544a56748c4b109e421b4b5da78319.apm.europe-west3.gcp.cloud.es.io:443' (source: Java System Properties)
2021-10-07 12:43:37,664 [main] INFO co.elastic.apm.agent.configuration.StartupInfo - application_packages: 'org.example' (source: Java System Properties)
2021-10-07 12:43:38,621 [main] INFO co.elastic.apm.agent.impl.ElasticApmTracer - Tracer switched to RUNNING state
Gerrit Code Review
usage: java -jar gerrit.war command [ARG ...]
The most commonly used commands are:
init Initialize a Gerrit installation
reindex Rebuild the secondary index
daemon Run the Gerrit network daemons
version Display the build version number
passwd Set or change password in secure.config
ls List files available for cat
cat FILE Display a file from the archive
At the end we would like to monitor applications hosted by us and not developed by us and can Elastic help us achieve it,................If not in the free atleast the paid version??
Thank you,
Anish
