How to print events and fields in Logstash using Ruby code?
Is there anyway I can print the events with ruby in Logstash?
Logstash.conf file:
    http {
        port => 9600
        id => "my_plugin_id"
    ruby {
        code => "puts event['message']"
output{
    stdout {
        codec => rubydebug {
            metadata => true
Error:
[2019-06-11T17:59:05,893][ERROR][logstash.filters.ruby ] Ruby exception occurred: undefined method `' for #LogStash::Event:0x642b9c0d
You can do it with
puts event.get('fieldName')
Yes, that worked, except fieldname needs to be in strings " ", and not ' '. Thanks for your help @shin-higuchi! :slightly_smiling_face:
Solution:
    ruby {
        code => 'puts event.get("message")'
or
    ruby {
        code => 'puts event.get("[message]")'
