How to raw logs to logstash default index and filtered log to another index
Hi All,
How can i configure logstash which can send all logs to default logstash-xxxx index and filtered log { i want only specific fields} will go to analytics index.
But I also want to have all raw logs in logstash index. Kindly help me.
Shamim Akhtar
This will allow for health check from Marathon
http {
port => 31210
type => "elb-healthcheck"
Default port is 12201/udp
gelf { port => 31212 }
some filter
// here i want filterd log
hosts => ["host:port"]
index => "business-%{+YYYY.MM.dd}"
document_type => "analytics"
// here i want all raw log
index => "logstash-%{+YYYY.MM.dd}"
document_type => "log"
You can do that using this method - https://www.elastic.co/guide/en/logstash/current/config-examples.html#using-conditionals
@warkolm :
Thanks for your reply.
if i do condition and output to different index. filtered log goes to business-index but raw log for login activity then does not go to default index.
what i want to do all login activity filtered log will go to business index and everything without filtered log will go to default logstash-xxx index
Thanks for your support.
if ... {
    index => "business"
Replace the first ... with whatever condition that matches login activity.
