Is logstash running, not getting messages after default pipeline workers
When i try to run my conf file, dont get any action after the settings line.
E:\ArchWorld\logstash-2.3.4\bin>logstash -f ../first.conf
io/console not supported; tty will not be manipulated
Settings: Default pipeline workers: 4
My conf file looks like this
input
file {
path => "E:\ArchWorld\temp\txn.log"
start_position => "beginning"
ignore_older => 0
The filter part of this file is commented out to indicate that it is
optional.
grok {
match => { "message" => "%{COMBINEDAPACHELOG}"}
stdout {}
With -v option this is what i get
E:\ArchWorld\logstash-2.3.4\bin>logstash agent -f E:\ArchWorld\logstash-2.3.4\first.conf -v
e[32mstarting agent {:level=>:info}e[0m
e[32mstarting pipeline {:id=>"main", :level=>:info}e[0m
e[32mRegistering file input {:path=>["E:\ArchWorld\temp\txn.log"], :level=>:info}e[0m
e[32mNo sincedb_path set, generating one based on the file path {:sincedb_path=>"C:\Users\SD00472887/.sincedb_b98e98cc115a6c233f1dc3807d0339bd", :path=>["E:\ArchWorld\temp\txn.log"], :level=>:info}e[0m
e[32mUsing mapping template from {:path=>nil, :level=>:info}e[0m
e[32mAttempting to install template {:manage_template=>{"template"=>"logstash-", "settings"=>{"index.refresh_interval"=>"5s"}, "mappings"=>{"default"=>{"_all"=>{"enabled"=>true, "omit_norms"=>true}, "dynamic_templates"=>[{"message_field"=>{"match"=>"message", "match_mapping_type"=>"string", "mapping"=>{"type"=>"string", "index"=>"analyzed", "omit_norms"=>true, "fielddata"=>{"format"=>"disabled"}}}}, {"string_fields"=>{"match"=>"", "match_mapping_type"=>"string", "mapping"=>{"type"=>"string", "index"=>"analyzed", "omit_norms"=>true, "fielddata"=>{"format"=>"disabled"}, "fields"=>{"raw"=>{"type"=>"string", "index"=>"not_analyzed", "ignore_above"=>256}}}}}], "properties"=>{"@timestamp"=>{"type"=>"date"}, "@version"=>{"type"=>"string", "index"=>"not_analyzed"}, "geoip"=>{"dynamic"=>true, "properties"=>{"ip"=>{"type"=>"ip"}, "location"=>{"type"=>"geo_point"}, "latitude"=>{"type"=>"float"}, "longitude"=>{"type"=>"float"}}}}}}}, :level=>:info}
Referred few other similar posts, but not sure of way ahead. Appreciate any help in this regard. Thanks.
Is new data going into the file?
I have the data from a dummy log file, like below
9962222248|FT|2016-08-01T11:01:01|TRN0000001
9962222247|FT|2016-08-01T11:01:11|TRN0000002
9962222246|FT|2016-08-01T11:01:21|TRN0000003
9962222245|FT|2016-08-01T11:01:31|TRN0000004
9962222244|FT|2016-08-01T11:01:41|TRN0000005
9962222243|FT|2016-08-01T11:01:01|TRN0000006
9962222242|FT|2016-08-01T11:01:51|TRN0000007
9962222241|FT|2016-08-01T11:01:60|TRN0000008
9962222248|FT|2016-08-01T11:02:01|TRN0000009
Yes but is there new data going into the file, or is the file static?
This is a static file
You will need to alter your ignore_older value then - https://www.elastic.co/guide/en/logstash/current/plugins-inputs-file.html#plugins-inputs-file-ignore_older
Currently I have specified it to 0, what should that be changed to ?
I'd leave it at the default myself.
Even did that earlier it doesnt work.
