elastic@ip-172-31-15-133:/opt/Elastic$ cd Agent/
-bash: cd: Agent/: Permission denied
elastic@ip-172-31-15-133:/opt/Elastic$ sudo -i
I think there's a restart button somewhere. It should recreate the VM if it was incorrectly created.
i don't think you need to hack around.
But may be someone from the @elastic.training team could help.
That's corret @dadoonet: there's no need to hack aroud.
@ganesh.pawar I have replaced your environment. Please follow lab instructions carefully, because sudo access is limited for installing and running the Elastic Agent only.
Best,
Andre
@dadoonet I also do not want to hack around for these kind of issues....but if basic command is not working for almost 2-3 weeks..what someone will do... I am on lab 2. after 3 weeks now ![]()
@Andre_Murbach_Maidl thanks....I hope this time it will worjk as expected...and I will be able to move t next labs....Again I do not want to play around with lab setup....but it should work as intended.....
I have problems at this point too.
Installation was successfull, but no data will be send. The agent status shows, that there are communication problems.
elastic@ip-172-31-2-34:~/elastic-agent-8.8.2-linux-x86_64$ ./elastic-agent status
Error: failed to communicate with Elastic Agent daemon: rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing dial unix /home/elastic/elastic-agent-8.8.2-linux-x86_64/data/tmp/elastic-agent-control.sock: connect: no such file or directory"
For help, please see our troubleshooting guide at Troubleshoot common problems | Fleet and Elastic Agent Guide [8.8] | Elastic
@elastic.training could you please reset my environment?
Hey,
I have the same error ![]()
lastic@ip-172-31-2-28:~/elastic-agent-8.8.2-linux-x86_64$ ./elastic-agent status
elastic@ip-172-31-2-28:~/elastic-agent-8.8.2-linux-x86_64$
And to get Agent installed I had to add –insecure on the enroll command …
Could you please help me on this case ?
Best regards
Lionel
