Kafka output gets permanently stuck after temporary wrong port — pipeline-to-pipeline address unavailable & retrying_send stall
I am facing an issue with Logstash Kafka output when the Kafka broker becomes temporarily unreachable.
Error :
[2025-12-05T12:41:32,869][WARN ][org.logstash.plugins.pipeline.AbstractPipelineBus][6c439cc070c5500b3acef737847adbb5978f7d66189e9c4591ef93fa3f24f09f] Attempted to send event to 'forward_kafka but that address was unavailable. Maybe the destination pipeline is down or stopping? Will Retry.
Problem Scenario
  • I intentionally changed the Kafka port to a wrong port (ex: 7879).
  • Logstash started showing Kafka connection errors (expected).
  • After a few seconds, I restored the correct port 7878 again.
  • Even after restoring the correct port, Logstash never recovers and it stops forwarding logs permanently.
  • Restarting Logstash fixes it, but I want Logstash to automatically recover without restart.
My Logstash pipeline forwards logs to Kafka using this output configuration:
  kafka {
    codec => json
    topic_id => "temp-logs"
    bootstrap_servers => "dev.custom.com:7878"
    client_id => "DEV-00135"
    security_protocol => "SASL_PLAINTEXT"
    sasl_mechanism => "PLAIN"
    sasl_jaas_config => "org.apache.kafka.common.security.plain.PlainLoginModule required username='admin' password='admin-secret';"
How to resolve this issue
If you like to reload configuration changes in .conf automatically, without LS restart, you can set in logstash.yml:
config.reload.automatic: true
config.reload.interval: 10s
You can set reconnect values in the kafka output params:
  • retries
  • retry_backoff_ms
  • reconnect_backoff_max_ms
  • reconnect_backoff_ms
  • request_timeout_ms
You can check default values, and do fine tuning for your case.
The kafka plugin v 10.50 is from April 2020, not sure which LS version do you have.
@Rios
I already have these values in logstash.yml
I have Logstash v 8.19.3
@Rios
retries => 10
retry_backoff_ms => 500
reconnect_backoff_ms => 500
request_timeout_ms => 30000
I have added these to my config but also the same issue persists
Shoes error like
What exactly you did and how are your pipelines connected? You mentioned that you are you using pipeline-to-pipeline communicaton, but you didn't share any of your configurations.
Please share your pipelines.yml file and the inputs and ouputs of all your pipelines running on the same instance.
@leandrojmp
  - pipeline.id: main_input
    path.config: "config/main_input.conf"
  - pipeline.id: input_snmp_trap
    path.config: "config/input_snmp_trap.conf"
  - pipeline.id: forward_syslog
    path.config: "config/forward_syslog.conf"
  - pipeline.id: input_eventlog
    path.config: "config/input_eventlog.conf"
    queue.max_bytes: 2048mb
    queue.type: persisted
  - pipeline.id: forward_eventlog
    path.config: "config/forward_eventlog.conf"
    queue.max_bytes: 1024mb
  - pipeline.id: forward_kafka
    path.config: "config/forward_kafka.conf"
    queue.max_bytes: 1000mb
These are my pipelines
Iam sending logs to the kafka forward pipeline like this.. To a separate pipeline from main_input pipeline. main_input pipeline is the entry point of logs
     if ("forward_event" not in [tags])
            hosts => ["localhost:9200"]
            index => "ScribblerCurrent"
    if ("forward_event" in [tags]) {
        pipeline {
            send_to => forward_Kafka
