Logstash and Grok filter problem with username
I try parser apache (access_log) log but i've problem with username section (not capture the complete name), log example:
10.13.252.185 - - [23/Aug/2020:23:56:14 -0400] "PROPFIND /remote.php/dav/files/JF009-01/PAPER/00022/document.txt HTTP/1.1" 207 1132 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.125 Safari/537.36"
My Grok filter is:
    grok {
      match => { "message" => '%{IPORHOST:clientip} - - \[%{HTTPDATE:timestamp}\] "%{WORD:Method} %{NOTSPACE:url}/%{NOTSPACE:user}/%{DATA:file} HTTP/%{NUMBER:httpversion}\" %{NUMBER:response} %{WORD:response_time}'
Where the username is: JF009-01 , but the filter only capture JF009 and the other section is captured inside folder tag .
  "clientip": [
      "10.13.252.185"
  "HOSTNAME": [
      "10.13.252.185"
  "IP": [
      null
  "IPV6": [
      null
  "IPV4": [
      null
  "timestamp": [
      "23/Aug/2020:23:56:14 -0400"
  "MONTHDAY": [
      "23"
  "MONTH": [
      "Aug"
  "YEAR": [
      "2020"
  "TIME": [
      "23:56:14"
  "HOUR": [
      "23"
  "MINUTE": [
      "56"
  "SECOND": [
      "14"
  "INT": [
      "-0400"
  "Method": [
      "PROPFIND"
  "user": [
      "JF009"
  "folder": [
      "-01/PAPER/00022"
  "file": [
      "document.txt"
  "httpversion": [
      "1.1"
  "BASE10NUM": [
      "1.1",
      "207"
  "response": [
      "207"
  "response_time": [
      "1132"
Any suggestions
The pattern and result that you posted do not fit together. There is no folder in your grok configuration.
