Logstash connection refused (using searchguard + monitoring x pack)
hello everyone ,
i am using elk stack via docker , for security access i use searchguard tool , then for monitor my stack i added x pack plugin with making security and other service that not free as false
( xpack.monitoring.enabled: true
xpack.graph.enabled: false
xpack.ml.enabled: false
xpack.security.enabled: false
xpack.watcher.enabled: false
in elasticseach.yml and kibana.yml )
so i could monitor kibana and ES and all okay for this part , but when i would added logstash to monitor i got an error and logstash wont start
logstash_1 | [2018-06-14T08:42:23,746][WARN ][logstash.outputs.elasticsearch] Attempted to resurrect connection to dead ES instance, but got an error. {:url=>"http://localhost:9200/", :error_type=>LogStash::Outputs::Elasticsearch::HttpClient::Pool::HostUnreachableError, :error=>"Elasticsearch Unreachable: [http://localhost:9200/][Manticore::SocketException] Connection refused (Connection refused)"}
elasticsearch_1 | [2018-06-14T08:42:24,727][WARN ][c.f.s.a.BackendRegistry ] Authentication finally failed for logstash
i dont know why the problem does not appear with kibana and ES but it did with logstash
can someone help me please
thank you
Looks like this has to do with searchguard, you will be probably better off posting in https://github.com/floragunncom/search-guard after you consult the plugins documentation.
