Logstash Pipeline is running successfully. Elasticsearch and Kibana are running successfully.
Have apache_access_xxxx.log files in logstash/event-data
Checked http://localhost:9200/_cat/indices and could not find logstash indices.
Pipeline.conf
file {
path => "C:/ELK-Stack/logstash/event-data/apache_*.log"
start_position => "beginning"
codec => plain{charset => 'UTF-16BE'}
http {
host => "localhost"
port => 8088
if [headers][request_uri] =~ "error" or [path] =~ "errors" {
mutate {
replace => { type => "error" }
} else {
mutate {
replace => { type => "access" }
	grok {
		match => { "message" => '%{HTTPD_COMMONLOG} "%{GREEDYDATA:referrer}" "%{GREEDYDATA:agent}"' }
	if "_grokparsefailure" in [tags] {
		drop { }
	useragent {
		source => "agent"
		target => "ua"
	# Admin pages
	if [request] =~ /^\/admin\// {
		drop { }
	# Static files
	if [request] =~ /^\/js\//
		or [request] =~ /^\/css\//
		or [request] in ["/robots.txt", "/favicon.ico"] {
		drop { }
	# Crawlers
	if [ua][device] == "Spider" {
		drop { }
	mutate {
		convert => {
			"response" => "integer"
			"bytes" => "integer"
	date {
		match => [ "timestamp", "dd/MMM/yyyy:HH:mm:ss Z" ]
		remove_field => [ "timestamp" ]
	geoip {
		source => "clientip"
mutate {
	remove_field => [ "headers", "@version", "host" ]
hosts => ["localhost:9200"]
document_type => "default"
#index => "%{type}-%{+YYYY.MM.dd}"
http_compression => true
