in my elk setup with logstash version 2.2 .i am trying to pull the messages from tibco jms broker on certain queue
for this my logstash config file is
input{
jms {
include_header => false
include_properties => false
include_body => true
use_jms_timestamp => false
interval => 10
yaml_file => "W:/jms.yml"
#queue_name => "emhjms"
destination => "emhjms"
yaml_section => "mybroker"
stdout {}
in the above code if i un comments queue_name its giving error
[31mUnknown setting 'queue_name' for jms {:level=>:error}←[0m
Error: Something is wrong with your configuration.
so i commented queue_name property
and my jms.yml file is
Tibco EMS
ems:
:jndi_name: QueueConnectionFactory
:jndi_context:
java.naming.factory.initial: com.tibco.tibjms.naming.TibjmsInitialContextFactory
java.naming.provider.url: tcp://localhost:7222
:require_jars:
- C:\software\tibco\ems\6.3\lib\jms.jar
- C:\software\tibco\ems\6.3\lib\tibjms.jar
- C:\software\tibco\ems\6.3\lib\tibcrypt.jar
after this if i running the logstash -f <filexxxx.config> i am getting error
←[33mJMS Consumer died {:exception=>#<TypeError: can't dup NilClass>, :backtrace=>["org/jruby/RubyKernel.java:2029:in dup'", "C:/Users/xprk313/Softwares/logstash-2.2.0/vendor/bundle/jruby/1.9/gems/jruby-jms-1.2.0-java/lib/jms/connectio 2.2.0/vendor/bundle/jruby/1.9/gems/jruby-jms-1.2.0-java/lib/jms/connection.rb:50:instart'", "C:/Users/xprk313/Softwares/logstash-2.2.0/vendor/bundle/jruby/1.9/gems/jruby-jms-1.2.0-java/lib/jms/connection.rb:70:in session'", "C:/Users ogstash-input-jms-2.0.2-java/lib/logstash/inputs/jms.rb:183:inrun_consumer'", "C:/Users/xprk313/Softwares/logstash-2.2.0/vendor/bundle/jruby/1.9/gems/logstash-input-jms-2.0.2-java/lib/logstash/inputs/jms.rb:261:in run'", "C:/Users/xp tash-core-2.2.0-java/lib/logstash/pipeline.rb:316:ininputworker'",
even i changed the yml file as mentioned below still same issue
com.tibco.tibjms.TibjmsConnectionFactory
:broker_url: tcp://localhost:7222
:username: admin
:password:
:require_jars:
