Logstash not creating index in kibana
After putting two space before path.config now pipelines.yml error resolve but getting another error
Aug 19 11:27:20 elastic.sys logstash[2119]: [2021-08-19T11:27:20,599][WARN ][logstash.outputs.elasticsearch][main] Attempted to resurrect connection to dead ES instance, but got an error {:url=>"https://logstash_writer:xxxxxx@elastic.sys:9200/", :exception=>LogStash::Outputs::ElasticSearch::HttpClient::Pool::BadResponseCodeError, :message=>"Got response code '401' contacting Elasticsearch at URL 'https://elastic.sys:9200/", :exception=>LogStash::Outputs::ElasticSearch::HttpClient::Pool::BadResponseCodeError, :message=>"Got response code '401' contacting Elasticsearch at URL 'https://elastic.sys:9200/'"}
It is an error of authentication more here.
Do you have the possibility to run logstash in debug mode to get more informations ?
[root@elastic logstash]# sudo bin/logstash --config.test_and_exit -f /etc/logstash/conf.d/syslog.conf
Using bundled JDK: /usr/share/logstash/jdk
OpenJDK 64-Bit Server VM warning: Option UseConcMarkSweepGC was deprecated in version 9.0 and will likely be removed in a future release.
WARNING: Could not find logstash.yml which is typically located in $LS_HOME/config or /etc/logstash. You can specify the path using --path.settings. Continuing using the defaults
Could not find log4j2 configuration at path /usr/share/logstash/config/log4j2.properties. Using default config which logs errors to the console
[INFO ] 2021-08-19 15:56:16.261 [main] runner - Starting Logstash {"logstash.version"=>"7.13.2", "jruby.version"=>"jruby 9.2.16.0 (2.5.7) 2021-03-03 f82228dc32 OpenJDK 64-Bit Server VM 11.0.11+9 on 11.0.11+9 +indy +jit [linux-x86_64]"}
[WARN ] 2021-08-19 15:56:17.699 [LogStash::Runner] multilocal - Ignoring the 'pipelines.yml' file because modules or command line options are specified
[INFO ] 2021-08-19 15:56:19.410 [LogStash::Runner] Reflections - Reflections took 151 ms to scan 1 urls, producing 24 keys and 48 values
[WARN ] 2021-08-19 15:56:20.718 [LogStash::Runner] udp - Relying on default value of `pipeline.ecs_compatibility`, which may change in a future major release of Logstash. To avoid unexpected changes when upgrading Logstash, please explicitly declare your desired ECS Compatibility mode.
[WARN ] 2021-08-19 15:56:21.428 [LogStash::Runner] elasticsearch - Relying on default value of `pipeline.ecs_compatibility`, which may change in a future major release of Logstash. To avoid unexpected changes when upgrading Logstash, please explicitly declare your desired ECS Compatibility mode.
Configuration OK
[INFO ] 2021-08-19 15:56:21.714 [LogStash::Runner] runner - Using config.test_and_exit mode. Config Validation Result: OK. Exiting Logstash
To run logstash in debug mode :
  • add the following line in the logstash.yml file.
log.level: debug
  • restart the service
Did you try to run a curl command to make sure of the validity of the password and username ?
After restart the service now getting this error
Aug 20 11:06:34 elastic.sys logstash[4110]: [2021-08-20T11:06:34,451][ERROR][logstash.outputs.elasticsearch][main] Failed to install template {:message=>"Got response code '403' contacting Elasticsearch at URL 'https://elastic.sys:9200/_template/logstash'", :exception=>LogStash::Outputs::ElasticSearch::HttpClient::Pool::BadResponseCodeError, :backtrace=>["/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/http_client/manticore_adapter.rb:80:in `perform_request'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:306:in `perform_request_to_url'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:293:in `block in perform_request'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:382:in `with_connection'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:292:in `perform_request'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:300:in `block in Pool'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/http_client.rb:379:in `exists?'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/http_client.rb:384:in `template_exists?'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/http_client.rb:80:in `template_install'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/template_manager.rb:29:in `install'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch/template_manager.rb:17:in `install_template'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch.rb:496:in `install_template'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch.rb:309:in `finish_register'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/outputs/elasticsearch.rb:279:in `block in register'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-output-elasticsearch-11.0.2-java/lib/logstash/plugin_mixins/elasticsearch/common.rb:145:in `block in after_successful_connection'"]}
Actually logstash_writer user doesn't authenticated so I changed the user in configuration file .Now user is logstash_system . Output of curl command
[root@elastic conf.d]# curl -XGET https://logstash_system:LiL14stC0M0BZw9iBAY9@elastic.sys:9200
  "name" : "elastic",
  "cluster_name" : "elasticsearch",
  "cluster_uuid" : "jSDbMD2dTO6478GtBOtyyg",
  "version" : {
    "number" : "7.13.2",
    "build_flavor" : "default",
    "build_type" : "rpm",
    "build_hash" : "4d960a0733be83dd2543ca018aa4ddc42e956800",
    "build_date" : "2021-06-10T21:01:55.251515791Z",
    "build_snapshot" : false,
    "lucene_version" : "8.8.2",
    "minimum_wire_compatibility_version" : "6.8.0",
    "minimum_index_compatibility_version" : "6.0.0-beta1"
logstash_writer seems to don't have the privilege to write index.
Take a look at the logstash_writer here
Btw, you should create a new topic to make it easier for people who can help you to do it. Moreover, this one have a lot of message.
