Logstash stops running after running for few seconds
My logstash stops running after 4 seconds of starting it, i get this output for systemctl status logstash -l
logstash.service - logstash
Loaded: loaded (/etc/systemd/system/logstash.service; disabled; vendor preset: disabled)
Active: active (running) since Thu 2017-08-03 18:46:53 UTC; 302ms ago
Main PID: 7521 (java)
CGroup: /system.slice/logstash.service
ââ7521 /usr/bin/java -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+DisableExplicitGC -Djava.awt.headless=true -Dfile.encoding=UTF-8 -XX:+HeapDumpOnOutOfMemoryError -Xmx4g -Xms1g -Xss2048k -Djffi.boot.library.path=/usr/share/logstash/vendor/jruby/lib/jni -Xbootclasspath/a:/usr/share/logstash/vendor/jruby/lib/jruby.jar -classpath : -Djruby.home=/usr/share/logstash/vendor/jruby -Djruby.lib=/usr/share/logstash/vendor/jruby/lib -Djruby.script=jruby -Djruby.shell=/bin/sh org.jruby.Main /usr/share/logstash/lib/bootstrap/environment.rb logstash/runner.rb --path.settings /etc/logstash
Aug 03 18:46:53 ip-10-x-x-250.domain.com systemd[1]: Started logstash.
Aug 03 18:46:53 ip-10-x-x-250.domain.com systemd[1]: Starting logstash...
There is no log file created in /var/log/logstash.
Any help is highly appreciated.
Although when i do a test against the config file, it pases the test and also when i start logstash using the command
bin/logstash -f /path/to/config/file , it gives the desired output, but it doesnt work when i try to start it as systemctl start logstash
hope when you are running it as user you are using 'sudo'
I am a root on the server.
Can anybody help me in resolving this issue? It has been down for sometime now.
when you start it as service logstash start did you check if its running or not ?
start the logstash and show me the output of
$ ps aux | grep logstash
everytime i run this command, i can see a new PID which means that it is trying to restart logstash every few seconds and is failing, finally after few unsuccessful attempts it fails forever and never restarts untill i run the start command again.
did you check logstash logs in /var/log/logstash?
Nothing logged to related to the startup failure, but here is the log i see :slight_smile:
[2017-08-04T15:22:13,694][INFO ][logstash.pipeline ] Starting pipeline {"id"=>"main", "pipeline.workers"=>2, "pipeline.batch.size"=>125, "pipeline.batch.delay"=>5, "pipeline.max_inflight"=>250}
[2017-08-04T15:38:42,520][INFO ][logstash.pipeline ] Pipeline main started
[2017-08-04T15:38:42,531][WARN ][logstash.runner ] SIGHUP received.
[2017-08-04T15:38:42,545][WARN ][logstash.runner ] SIGTERM received. Shutting down the agent.
[2017-08-04T15:38:42,558][ERROR][logstash.inputs.metrics ] Failed to create monitoring event {:message=>"For path: http_address", :error=>"LogStash::Instrument::MetricStore::MetricNotFound"}
[2017-08-04T15:38:42,589][INFO ][logstash.agent ] Successfully started Logstash API endpoint {:port=>9600}
[2017-08-04T15:38:43,565][WARN ][logstash.agent ] stopping pipeline {:id=>".monitoring-logstash"}
[2017-08-04T15:38:45,517][WARN ][logstash.agent ] stopping pipeline {:id=>"main"}
run it using strace and save the output to a file and share it with us.
whats the command to run it using strace?
before that did you try to run it manually from /usr/share/logstash ?
$ cd /usr/share/logstash
$ bin/logstash -f /etc/logstash.d/conf/yourfile.conf
and see if it runs properly
Yes i ran it manually using this command, and i am still running it using just one config file. It works like a champ. But not with systemctl start logstash
ok so start it as service again and show me the output of
$systemctl status logstash
