Hi All
I know this question has been asked earlier as well, but this issue is still there.
But there was no clear statement on the solution, so i am asking again.
input : jdbc-input-plugin
jdbc driver: MSSQL
Underneath jdbc input plugin uses this format/template
SELECT count(*) AS count FROM
select .......
AS t1 LIMIT 1
When i use Order by query, it just utilizes the above template
select .......
order by a.id asc
AS t1 LIMIT 1
with this i get this error
The ORDER BY clause is invalid in views, inline functions, derived tables, subqueries, and common table expressions, unless TOP, OFFSET or FOR XML is also specified.
Now i cannot go and change the jdbc-input plugin template and get rid of that count. The count is also important because, i need to enable pagination
I do not need solution without pagination because i have millions on record, so pagination is necessary and to do that i need to do order by ascending.
Is there any other way to do ascending order?
But the above order by query works in other Databases, only MSSQL server is a problem
