Meta engine vs sub-engine tuning
Does anyone have more information on how tuning works between Meta engines and sub-engines? I'd like to find a way to weight sub-engine A more than sub-engine B. How have others approached this?
Hi @nottocc ,
The most common way we've seen folks address this is to add a field to both sub engines like source_engine that you can set a boost on from your meta engine.
