I would like throttle events using the logstash-filter-throttle plugin. After that to create a logstash-filter-metric to push it to prometheus using graphite exporter. And finally drop the events that are marked by the throttle plugin.
The issue I face is when I use de drop plugin the metric event does not get created.
Is there way to have both the drop filter and metric filter coexist?
throttle {
id => "main_throttle_filter"
enable_metric => true
before_count => -1
after_count => 50
period => 60
max_age => 120
key => "%{[fields][platform]}"
add_tag => "throttled_events"
if "throttled_events" in [tags] {
metrics {
id => "throttled_metrics"
meter => "logstash_throttled_total.%{[fields][platform]}"
rates => []
add_tag => "throttled_metrics"
flush_interval => 30
ignore_older_than => 120
drop {
id => my_throttled_events_drop
if "throttled_metrics" in [tags] {
graphite {
host => "${GRAPHITE_HOST}"
port => "${GRAPHITE_PORT}"
fields_are_metrics => true
} else {
user => logstash_internal
password => "${LOGSTASH_PASS}"
ssl => true
cacert => '/usr/share/logstash/config/ca_cert.pem'
hosts => ["${ELASTICSEARCH_HOST}:${ELASTICSEARCH_PORT}"]
manage_template => false
