When testing the modules:
./metricbeat test modules -e
{"log.level":"info","@timestamp":"2024-04-06T11:09:35.445Z","log.origin":{"function":"github.com/elastic/beats/v7/libbeat/cmd/instance.(*Beat).configure","file.name":"instance/beat.go","file.line":811},"message":"Home path: [/usr/share/metricbeat] Config path: [/usr/share/metricbeat] Data path: [/usr/share/metricbeat/data] Logs path: [/usr/share/metricbeat/logs]","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2024-04-06T11:09:35.445Z","log.origin":{"function":"github.com/elastic/beats/v7/libbeat/cmd/instance.(*Beat).configure","file.name":"instance/beat.go","file.line":819},"message":"Beat ID: a36bcdf9-7ac6-438f-8a28-668ca0b8a5ef","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2024-04-06T11:09:35.448Z","log.logger":"add_cloud_metadata","log.origin":{"function":"github.com/elastic/beats/v7/libbeat/processors/add_cloud_metadata.(*addCloudMetadata).fetchMetadata","file.name":"add_cloud_metadata/providers.go","file.line":173},"message":"add_cloud_metadata: received error failed requesting digitalocean metadata: Get \"http://169.254.169.254/metadata/v1.json\": dial tcp 169.254.169.254:80: connect: connection refused","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2024-04-06T11:09:35.449Z","log.logger":"add_cloud_metadata","log.origin":{"function":"github.com/elastic/beats/v7/libbeat/processors/add_cloud_metadata.(*addCloudMetadata).fetchMetadata","file.name":"add_cloud_metadata/providers.go","file.line":173},"message":"add_cloud_metadata: received error failed requesting azure metadata: Get \"http://169.254.169.254/metadata/instance/compute?api-version=2021-02-01\": dial tcp 169.254.169.254:80: connect: connection refused","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2024-04-06T11:09:35.450Z","log.logger":"add_cloud_metadata","log.origin":{"function":"github.com/elastic/beats/v7/libbeat/processors/add_cloud_metadata.(*addCloudMetadata).fetchMetadata","file.name":"add_cloud_metadata/providers.go","file.line":173},"message":"add_cloud_metadata: received error failed requesting openstack metadata: Get \"http://169.254.169.254/2009-04-04/meta-data/instance-id\": dial tcp 169.254.169.254:80: connect: connection refused","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2024-04-06T11:09:35.451Z","log.logger":"add_cloud_metadata","log.origin":{"function":"github.com/elastic/beats/v7/libbeat/processors/add_cloud_metadata.(*addCloudMetadata).fetchMetadata","file.name":"add_cloud_metadata/providers.go","file.line":173},"message":"add_cloud_metadata: received error failed requesting gcp metadata: Get \"http://169.254.169.254/computeMetadata/v1/?recursive=true&alt=json\": dial tcp 169.254.169.254:80: connect: connection refused","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2024-04-06T11:09:35.452Z","log.logger":"add_cloud_metadata","log.origin":{"function":"github.com/elastic/beats/v7/libbeat/processors/add_cloud_metadata.(*addCloudMetadata).fetchMetadata","file.name":"add_cloud_metadata/providers.go","file.line":173},"message":"add_cloud_metadata: received error failed requesting openstack metadata: Get \"https://169.254.169.254/2009-04-04/meta-data/placement/availability-zone\": dial tcp 169.254.169.254:443: connect: connection refused","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2024-04-06T11:09:35.453Z","log.logger":"add_cloud_metadata","log.origin":{"function":"github.com/elastic/beats/v7/libbeat/processors/add_cloud_metadata.(*addCloudMetad
ata).fetchMetadata","file.name":"add_cloud_metadata/providers.go","file.line":173},"message":"add_cloud_metadata: received error failed requesting hetzner metadata: Get \"http://169.254.169.254/hetzner/v1/metadata/availability-zone\": dial tcp 169.254.169.254:80: connect: connection refused","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"warn","@timestamp":"2024-04-06T11:09:35.481Z","log.logger":"tls","log.origin":{"function":"github.com/elastic/elastic-agent-libs/transport/tlscommon.(*TLSConfig).ToConfig","file.name":"tlscommon/tls_config.go","file.line":107},"message":"SSL/TLS verifications disabled.","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2024-04-06T11:09:35.486Z","log.logger":"kubernetes","log.origin":{"function":"github.com/elastic/elastic-agent-autodiscover/kubernetes.DiscoverKubernetesNode","file.name":"kubernetes/util.go","file.line":130},"message":"kubernetes: Node pf4bwj30 discovered by in cluster pod node query","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"warn","@timestamp":"2024-04-06T11:09:35.495Z","log.logger":"tls","log.origin":{"function":"github.com/elastic/elastic-agent-libs/transport/tlscommon.(*TLSConfig).ToConfig","file.name":"tlscommon/tls_config.go","file.line":107},"message":"SSL/TLS verifications disabled.","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2024-04-06T11:09:35.497Z","log.logger":"kubernetes","log.origin":{"function":"github.com/elastic/elastic-agent-autodiscover/kubernetes.DiscoverKubernetesNode","file.name":"kubernetes/util.go","file.line":130},"message":"kubernetes: Node pf4bwj30 discovered by in cluster pod node query","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"warn","@timestamp":"2024-04-06T11:09:35.502Z","log.logger":"tls","log.origin":{"function":"github.com/elastic/elastic-agent-libs/transport/tlscommon.(*TLSConfig).ToConfig","file.name":"tlscommon/tls_config.go","file.line":107},"message":"SSL/TLS verifications disabled.","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2024-04-06T11:09:35.503Z","log.origin":{"function":"github.com/elastic/beats/v7/metricbeat/module/kubernetes/util.AddClusterECSMeta","file.name":"util/kubernetes.go","file.line":745},"message":"could not retrieve cluster metadata: fail to get kubernetes cluster metadata: unable to retrieve cluster identifiers","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"warn","@timestamp":"2024-04-06T11:09:35.503Z","log.logger":"tls","log.origin":{"function":"github.com/elastic/elastic-agent-libs/transport/tlscommon.(*TLSConfig).ToConfig","file.name":"tlscommon/tls_config.go","file.line":107},"message":"SSL/TLS verifications disabled.","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2024-04-06T11:09:35.505Z","log.origin":{"function":"github.com/elastic/beats/v7/metricbeat/module/kubernetes/util.AddClusterECSMeta","file.name":"util/kubernetes.go","file.line":745},"message":"could not retrieve cluster metadata: fail to get kubernetes cluster metadata: unable to retrieve cluster identifiers","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"warn","@timestamp":"2024-04-06T11:09:35.505Z","log.logger":"tls","log.origin":{"function":"github.com/elastic/elastic-agent-libs/transport/tlscommon.(*TLSConfig).ToConfig","file.name":"tlscommon/tls_config.go","file.line":107},"message":"SSL/TLS verifications disabled.","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2024-04-06T11:09:35.507Z","log.origin":{"function":"github.com/elastic/beats/v7/metricbeat/module/kubernetes/util.AddClusterECSMeta","file.name":"util/kubernetes.go","file.line":745},"message":"could not retrieve cluster metadata: fail to get kubernetes cluster metadata: unable to retrieve cluster identifiers","service.name":"metricbeat","ecs.version":"1.6.0"}
kubernetes...
pod...{"log.level":"warn","@timestamp":"2024-04-06T11:09:35.809Z","log.logger":"tls","log.origin":{"function":"github.com/elastic/elastic-agent-libs/transport/tlscommon.(*TLSConfig).ToConfig","file.name":"tlscommon/tls_config.go","file.line":107},"message":"SSL/TLS verifications disabled.","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2024-04-06T11:09:38.446Z","log.logger":"add_cloud_metadata","log.origin":{"function":"github.com/elastic/beats/v7/libbeat/processors/add_cloud_metadata.(*addCloudMetada
ta).init.func1","file.name":"add_cloud_metadata/add_cloud_metadata.go","file.line":100},"message":"add_cloud_metadata: hosting provider type not detected.","service.name":"metricbeat","ecs.version":"1.6.0"}
error... ERROR timeout waiting for an event
container...
system...OK
result:
"@timestamp": "2024-04-06T11:09:45.509Z",
"event": {
"dataset": "kubernetes.system",
"duration": 130385,
"module": "kubernetes"
"kubernetes": {
"node": {
"name": "pf4bwj30"
"system": {
"container": "kubelet",
"cpu": {
"usage": {
"core": {
"ns": 15900525606776
"nanocores": 326532903
"memory": {
"majorpagefaults": 6681,
"pagefaults": 37260172,
"rss": {
"bytes": 22427107328
"usage": {
"bytes": 24825720832
"workingset": {
"bytes": 24326336512
"start_time": "2024-04-05T16:35:30Z"
"metricset": {
"name": "system",
"period": 20000
"service": {
"address": "https://pf4bwj30:10250/stats/summary",
"type": "kubernetes"
volume...
apiserver...{"log.level":"warn","@timestamp":"2024-04-06T11:09:50.510Z","log.logger":"tls","log.origin":{"function":"github.com/elastic/elastic-agent-libs/transport/tlscommon.(*TLSConfig).ToConfig","file.name":"tlscommon/tls_config.go","file.line":107},"message":"SSL/TLS verifications disabled.","service.name":"metricbeat","ecs.version":"1.6.0"}
OK
result:
"@timestamp": "2024-04-06T11:09:50.510Z",
"event": {
"dataset": "kubernetes.apiserver",
"duration": 146790871,
"kubernetes": {
"apiserver": {
"major": {
"version": "1"
"minor": {
"version": "28"
"request": {
"code": "200",
"component": "apiserver",
"count": 4,
"group": "apiextensions.k8s.io",
"resource": "customresourcedefinitions",
"scope": "resource",
"verb": "GET",
"version": "v1"
"metricset": {
"name": "apiserver",
"period": 20000
"service": {
"address": "https://pf4bwj30:10250/metrics",
