I am trying to connect to metricbeat zookeeper module to zookeeper through ssl connection. Though I am able to connect in non ssl mode I am unable to connect through ssl.
I get the below errors
srvr command failed: read failed: read tcp 10.12.2.54:63943->10.11.54.57:2181: i/o timeout mntr command failed: read failed: read tcp 10.12.2.54:63942->10.11.54.57:2181: i/o timeout
zookeeper.yml configuration is
`- module: zookeeper
` metricsets:
` - mntr
` - server
` period: 10s
` hosts: ["host.xxx.com:2181"]
` ssl.enabled: true
` ssl.certificate: "C:\\Elastic\\Certificate\\Zookeeper\\certf3.pem"
` ssl.key: "C:\\Elastic\\Certificate\\Zookeeper\\keyf3.key"
