We want to use the docker.diskio.read/write.rate metric to monitor our systems. However, Metricbeat's Docker module reports all docker.diskio metrics (except the docker.diskio.read/write.bytes metric) as zero when using a Linux system with cgroups v2.
System Configuration:
- Metricbeat 8.11.1
- Docker 24.0.7
- Ubuntu 22.04
We use the following (slightly truncated) Metricbeat configuration:
metricbeat.modules:
- module: docker
enabled: true
period: 60s
metricsets: [ diskio ]
hosts: ["unix:///var/run/docker.sock"]
output.console:
enabled: true
codec.json:
pretty: true
Output when using cgroups v1 (as exepcted):
"docker": {
"diskio": {
"read": {
"wait_time": 0,
"queued": 0,
"ops": 0,
"bytes": 0,
"rate": 0,
"service_time": 0
"write": {
"queued": 0,
"ops": 14745,
"bytes": 3867148288,
"rate": 351.365903663928,
"service_time": 0,
"wait_time": 0
"summary": {
"service_time": 0,
"wait_time": 0,
"queued": 0,
"ops": 14745,
Output when using cgroups v2 (rate and ops are always zero which is not expected):
"docker": {
"diskio": {
"read": {
"wait_time": 0,
"queued": 0,
"ops": 0,
"bytes": 0,
"rate": 0,
"service_time": 0
"write": {
"queued": 0,
"ops": 0,
"rate": 0,
"service_time": 0,
"wait_time": 0
"summary": {
"service_time": 0,
"wait_time": 0,
"queued": 0,
"ops": 0,
"rate": 0
Is this a (known) problem, or is this even desired behavior?
