Multi output for multi prospectors
I use ELK 5.0.1 + Filebeat 5.0.1.
On my server I have 2 kind of prospectors :
  • json logs
  • text logs
Currently, I configure Filebeat to send the json logs directly to elasticsearch.
This works fine.
Now I want to send the text logs to logstash to parse them with a grok filter.
In the Filebeat configuration, I don't find how to use 2 output for this 2 prospectors.
Is it possible ?
How can I do this ?
It is not possible to route the events to different outputs. All events go to all outputs. So you can send it all to Logstash and then route the events from there.
