Multiline codec - max_age setting not recognized
03:40:16.497 [LogStash::Runner] ERROR logstash.codecs.multiline - Unknown setting 'max_age' for multiline
CentOS release 6.8 (Final)
logstash 5.0.0
Yes. As documented, the multiline codec doesn't have a max_age option. Perhaps auto_flush_interval solves the same problem for you?
Thank you for your reply.
For some reason I thought max_age was documented under both filter plugin and codec. Checking again, that isn't the case.
auto_flush_interval does indeed solve the problem. Merci!
