Hi Experts,
I am aware that I can use following to create date index .
index => "prod-%{+YYYY.MM.dd}" but the problem is, it is picking up logs date rather current date, what I want is to create index on current date basis. Please suggest how I can achieve this ?
VG
I don't understand why you'd want to do that, but the easiest way is probably to store today's date in a @metadata field and reference that field in the output. Something like this:
ruby {
code => "event['@metadata']['now'] = Time.new.strftime('%Y-%m-%d')"
index => "prod-%{@[metadata][now]}"
@magnusbaeck,
Thank you for quick response , with above index is getting created but as follows
Index name Doc Count
prod-%{[metadata][now]} 7089
Actually my requirement is to just create index on current date , something like prod-2-26-2016
I get it @ was missing , thanks it works
Yes, sorry. I updated the post.
