Need help with 403 errors Logstash 6.2.4 with X-Pack
Everythign was working fine until I installed X-Pack on a remote logstash server. Now I am geting this error:
[2018-05-22T18:30:12,500][ERROR][logstash.config.sourceloader] Could not fetch all the sources {:exception=>LogStash::Outputs::ElasticSearch::HttpClient::Pool::BadResponseCodeError, :message=>"Got response code '403' contacting Elasticsearch at URL 'http://IPADDRES:9200/.logstash/doc/_mget'", :backtrace=>["/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-output-elasticsearch-9.1.1-java/lib/logstash/outputs/elasticsearch/http_client/manticore_adapter.rb:80:in perform_request'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-output-elasticsearch-9.1.1-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:291:inperform_request_to_url'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-output-elasticsearch-9.1.1-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:278:in block in perform_request'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-output-elasticsearch-9.1.1-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:373:inwith_connection'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-output-elasticsearch-9.1.1-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:277:in perform_request'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-output-elasticsearch-9.1.1-java/lib/logstash/outputs/elasticsearch/http_client/pool.rb:285:inblock in post'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/logstash-output-elasticsearch-9.1.1-java/lib/logstash/outputs/elasticsearch/http_client.rb:166:in post'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/x-pack-6.2.4-java/lib/config_management/elasticsearch_source.rb:127:infetch_config'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/x-pack-6.2.4-java/lib/config_management/elasticsearch_source.rb:73:in pipeline_configs'", "/usr/share/logstash/logstash-core/lib/logstash/config/source_loader.rb:59:inblock in fetch'", "org/jruby/RubyArray.java:2481:in collect'", "/usr/share/logstash/logstash-core/lib/logstash/config/source_loader.rb:58:infetch'", "/usr/share/logstash/logstash-core/lib/logstash/agent.rb:148:in converge_state_and_update'", "/usr/share/logstash/logstash-core/lib/logstash/agent.rb:105:inblock in execute'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/stud-0.0.23/lib/stud/interval.rb:18:in interval'", "/usr/share/logstash/logstash-core/lib/logstash/agent.rb:94:inexecute'", "/usr/share/logstash/logstash-core/lib/logstash/runner.rb:348:in block in execute'", "/usr/share/logstash/vendor/bundle/jruby/2.3.0/gems/stud-0.0.23/lib/stud/task.rb:24:inblock in initialize'"]}
I have set up the passwords for logstash_system and elastic and put them in logstash.yml like this:
xpack.monitoring.elasticsearch.username: logstash_system
xpack.monitoring.elasticsearch.password: PASSWORD
xpack.management.elasticsearch.username: logstash_system
xpack.management.elasticsearch.password: PASSWORD
xpack.monitoring.elasticsearch.url: "http://IPADDRFESS:9200"
xpack.management.enabled: true
xpack.management.elasticsearch.url: "http://IPADDRESS:9200"
in my syslog.conf file i added this:
hosts => ["IPADDRESS"]
manage_template => false
user => "elastic"
password => PASSWORD!"
If I go to the URL I get this in Chrome once I log in as logstash_system:
"name" : "node-name",
"cluster_name" : "elasticsearch",
"cluster_uuid" : "bunch of stuff",
"version" : {
"number" : "6.2.4",
"build_hash" : "ccec39f",
"build_date" : "2018-04-12T20:37:28.497551Z",
"build_snapshot" : false,
"lucene_version" : "7.2.1",
"minimum_wire_compatibility_version" : "5.6.0",
"minimum_index_compatibility_version" : "5.0.0"
I have been looking and have not found this error... Can soembody let me know how to get this working?
Thanks!!
Nver mind, blew away logstash and reinstalled it then did the x_pack install again and it worked
