After enabling the persistent queue some of our cef logs could no longer be parsed.
The Logs semed to be split wrong.
The config looks as follows:
tcp {
port => 5514
type => "forti_log"
codec => "cef"
#The Fortigate syslog contains a type field as well, we'll need to rename that field in order for this to work
if [type] == "forti_log" {
grok{
match => ["syslog", "%{SYSLOG5424PRI:syslog_index}%{SYSLOGTIMESTAMP:date} %{NOTSPACE:logsource}"]
kv {
source => "message"
value_split => "="
#Expects you have csv enable set on your Fortigate. If not I think you'll have to change it to " " but I didn't test that.
field_split => " "
mutate {
#The syslog contains a type field which messes with the Logstash type field so we have to rename it.
rename => { "type" => "ftg_type" }
rename => { "subtype" => "ftg_subtype" }
add_field => { "type" => "forti_log" }
convert => { "rcvdbyte" => "integer" }
convert => { "sentbyte" => "integer" }
date {
match => ["FTNTFGTeventtime", "UNIX" ]
target => "FTNTFGTeventtime"
date {
match => [ "date", "MMM dd HH:mm:ss" ]
target => "@timestamp"
mutate {
#add/remove fields as you see fit.
remove_field => ["syslog_index","syslog","syslog5424_pri","path","service","date","time","sentpkt","rcvdpkt","log_id","poluuid"]
Is this a known problem that could be solved with a simple upgrade of logstash?
