I've created a docker image for filebeat for arm64 arch. This is what my simplistic docker file looks like
    FROM golang:1.15.10
    RUN \
    apt-get update \
      && apt-get install -y --no-install-recommends \
         libsystemd-dev \
         netcat \
         rsync \
         python \
         python-pip \
         python3 \
         python3-pip \
         python3-venv \
         libpcap-dev \
      && rm -rf /var/lib/apt/lists/*
    RUN cd /
    RUN wget https://artifacts.elastic.co/downloads/beats/filebeat/filebeat-7.9.0-arm64.deb
    RUN dpkg -i filebeat-7.9.0-arm64.deb
It builds ok but when I run it up I get this error
Error: failed to create containerd task: OCI runtime create failed: container_linux.go:370: starting container process caused: exec: "-c": executable file not found in $PATH: unknown
(For info this is inside of microk8s, but may or may not be relevant.)
Have I missed a step in the docker file? Can anyone point me to a simple docker file that would successfully do what I am trying to do here?
