Problem parsing a datestring - Grok Debugger shows no problem
Example Logfile Entry which works perfectly in the Grok Debugger:
2018-11-21 08:15:54,809 WARN [com.xxx.mediaserver.tools.maintenance.FileMaintenance] (Thread-6) Not removing directory C:\xxx\mediaserver\import_export\SUPERVISOR\Downloads\packaged_ko_40186264_40186283 because we're not sure if it was created by us (directory name mismatch).
Here's the identification string:
%{DATE:date}%{SPACE}%{TIME:timestamp}%{SPACE}%{WORD:loglevel}%{SPACE}\[(?<class>.+?(?=]))\]%{SPACE}\((?<thread>.+?(?=\)))\)%{SPACE}(?<logmessage>.*)
And here's the logstash part:
grok { match => { "message" => "%{DATE:date}%{SPACE}%{TIME:timestamp}%{SPACE}%{WORD:loglevel}%{SPACE}[(?.+?(?=]))]%{SPACE}((?.+?(?=))))%{SPACE}(?.*)" } }
mutate { add_field => { "access_time" => "%{date} %{timestamp}" } }
date { match => [ "access_time", "YY-MM-dd HH:mm:ss,SSS" ] }
mutate {
remove_field => [ "SPACE" ]
remove_tag => [ "beats_input_codec_plain_applied", "monitor", "apache" ]
add_tag => [ "mediaserver" ]
In the field access_time i have this:
%{month} %{day} %{year} %{hour}:%{minute}:%{seconds}
so it seems, date parsing fails.
I also have this in field thread which makes no sense:
because my regexp is parsing for the finishing ")" which works perfectly in Grok Debugger and ALSO in another part of the logstash config, which i post below:
This works perfectly:
  else if [quelle] == "wildfly-main" {
    grok { match => { "message" => "%{DATE:date}%{SPACE}%{TIME:timestamp}%{SPACE}%{WORD:loglevel}%{SPACE}\[(?<class>.+?(?=:)):%{INT:linenumber}\]%{SPACE}\((?<thread>.+?(?=\)))\)%{SPACE}(?<logmessage>.*)" } }
	mutate {
	  remove_field => [ "SPACE", "date", "timestamp", "message" ]
	  add_tag => [ "wildfly" ]
Any reason that this part is different to this:
copy&paste error. this is the correct part in the logstash-config:
  else if [quelle] == "mediaserver-main" {
    grok { match => { "message" => "%{DATE:date}%{SPACE}%{TIME:timestamp}%{SPACE}%{WORD:loglevel}%{SPACE}\[(?<class>.+?(?=]))\]%{SPACE}\((?<thread>.+?(?=\)))\)%{SPACE}(?<logmessage>.*)" } }
	mutate {
So yes, i double and tripple checked that the correct string (which works in Grok Debugger) is also in the Logstash-Config. I am unable to find out why it doesn't work. I have another else if block with almost the exact same string which works like explained :frowning:
Testing your Grok only it works for me:
I will try the rest of the filter tomorrow when I have more time.
yes, that's the funny thing. The second part in the logstash almost parses the same and it works aswell. I don't get it, try to solve it since 2-3 days.
What i did additionally:
  • Completely deleted indices in Elastic
  • Rebuild fields in Elastic
  • Reconfigured positioning in Logstash
Still the same problem :confused:
fixed the problem myself.
And now comes the funny part:
I just changed the position of the "else if" block in the logstash config. Nothing else.
Since then it works like expected.
I even copied it back to the original position (last one) and it still works.
Sometimes strange things happen and resolve themselves ...
